Horsepower!!!!
Old Mar 5, 2007 | 07:37 PM
singh's Avatar
singh
_______________
^^I just realized your a female!!
Old Mar 5, 2007 | 07:54 PM
350Zzzz's Avatar
350Zzzz
Professional
Originally Posted by Skyebaby
Thanks for your input.. I dont kno what crank is though....what about changing the airfilter? wont that get u some hp?? or a chip? any thought and price?
What sort of budget have you put aside for your mods? And, apart from adding hp, what do you wish to achieve with your Z?
Moving to the ECU (chip) could accelarate you into the $500 budget range & upwards and you may not reach your 15 hp gain that you're shooting for. In most cases going the ECU direction on a Naturally Aspirated VQ (in your case) will not give you the cost to power gains that you're seeking.
From what I've been told, a hydra on a rental NA bone stock Z the gains were 20 + hp. The Hydra is a stand alone EMS direct ECU swap, which is listed at $1950; probably a few $100 less, street price. Taking the ECU (chip) path may not do much for you, even the UTEC which is only a piggy-back will run you in the $1000 range and cost as much as the hydra after tuning and set-up.
G
__________
Old Mar 5, 2007 | 07:57 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Hey-
I'm new to the z. just got mine a few months ago. Blue roadster tour 06....And I'm a 22F so I know nothing about cars! I was wondering how to increase HP without spending a ton. I want to get to 300hp. (287hp right now, aT)....Any thoughts??? Thanks
-Danielle
IMO in order of importance:
Motordyne 5/16" spacer
technosquare reflash OR UTEC+tuning session
Test pipes or high flow cats of your choice
2.25" true dual exhaust
If you don't know what any of the above are, you need to start searching and doing independent research
Old Mar 5, 2007 | 08:57 PM
HpnoticZ's Avatar
HpnoticZ
sorry a whip is a car. I just want to see what we are dealing with here. Im sure if you post picture you will get more help and i might give you my intake free of charge.
Old Mar 5, 2007 | 09:30 PM
cvt's Avatar
cvt
it seems she only wants a 13hp at the flywheel gain....i think a spacer and exhaust would do it. motordyne + nismo would do it.
Dymsi
Sep 29, 2015 11:32 AM
torchkc
Sep 11, 2015 08:26 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
eskimo
Nitrous Oxide
282
Jan 30, 2011 03:22 PM
