UR Crank Pully
Old Mar 29, 2007 | 10:05 PM
joonsuh012's Avatar
joonsuh012
Default UR Crank Pully
does the ONLY UR crank pully makes the revving faster??? is it noticible??
i just make sure 100% before i order one..
i wanna check out video but .....could not find it
(i 've been using search button..couldn't find the answer i want)
please help! thanks
Old Mar 30, 2007 | 05:31 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Wow! First, your writing skills aren't so great. However, Yes only get the crank pulley. The kit is not worth the investment (IMO).
Old Mar 30, 2007 | 07:37 AM
Dubai's Avatar
Dubai
true. just get the crank pulley. and yes the revving will be slightly faster.
Old Mar 30, 2007 | 08:21 AM
RebelinRI's Avatar
RebelinRI
If you want to cut down on your rotating mass, save your money for a lightened flywheel. Much better investment.
Old Mar 30, 2007 | 06:48 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
and alot more expensive to install
the pulley is an easy install and is absolutely noticeable. Combined with a lightweight flywheel and it's a different car altogether
the UR pulley is, for the cost, absolutely worthwhile
http://www.z1auto.com/prodmore.asp?m...ine&prodid=718
Old Mar 31, 2007 | 09:32 AM
Armitage's Avatar
Armitage
Anyone had any long term issues with it? I know in the past other cars have had issues with the crank pulleys but I haven't seen many issues with the Z crank pulleys.
Old Mar 31, 2007 | 09:36 AM
Mike Wazowski's Avatar
Mike Wazowski
I have 43,000 miles on mine with no problems what so ever.
Old Apr 2, 2007 | 01:24 PM
G35cTT's Avatar
G35cTT
Just curious I notice you had a TT kit on your car, do you have the whole kit or just the crank pulley? Was it a little difference or major?
Old Apr 2, 2007 | 01:26 PM
failsafe's Avatar
failsafe
....for your health
+1 I have about 40K on mine- no problems
Old May 7, 2007 | 09:25 AM
pimpin714style's Avatar
pimpin714style
whats the down fall of having the whole kit? i was looking into getting the set but im glad i found this thread.
Old May 7, 2007 | 06:18 PM
zdero's Avatar
zdero
I don't think there is a downfall to having the whole kit, other than the other two pulleys aren't neccessary. I know they are hard to see, but I got the whole kit just for looks. But the only pulley you need for performance gains is the crank pulley.
Old May 8, 2007 | 04:58 AM
Netko350Z's Avatar
Netko350Z
Just make sure you get it installed correctly. If you screw it up you will have some problems.
Old May 8, 2007 | 05:07 AM
RKnight's Avatar
RKnight
Problem with the crank pully is that it doen't dampen harmonic vibrations because it is solid metal. A top engine builder here in Orange Co. told me he would never recommend using one.
Old May 8, 2007 | 02:57 PM
VQLOVER's Avatar
VQLOVER
He's dumb...show him the stock pulley and ask him if it dampens harmonic vibrations, because guess what....it's solid metal.
Old May 8, 2007 | 03:05 PM
Z1 Performance
Former Sponsor
I wouldnt use one on a 57 Chevy (unless I built a motor and balanced it all together), but a Z pulley is not like this....it does not dampen
Old May 9, 2007 | 05:16 AM
RKnight's Avatar
RKnight
I stand corrected on the Z motor. Have tried to see if the pully was solid on the VQ and it looked solid but couldn't tell for sure. The situation I was talking to my engine builder about was for my Mazda, and Honda motors that do have a rubber dampening ring. It is interesting that Relentless does use a dampened pully on the Double Down Z.
Old May 9, 2007 | 05:38 AM
Z1 Performance
Former Sponsor
dampened pullies, like a fluid dampr type unit, are also a great solution for very high HP, high rpm sustained use.
At the end of the day, its really up to the person assembling the motor as to which route they want to go. Many machinists will want to use the stock unit, many will choose a lightened and or underdriven aftermarket pulley, and many will choose the fluid dampr unit. There is honestly no "right" or "wrong" way, just different. At the end of the day, it all depends how well the internal parts of the engine themselves are balanced, as well as the level of balance that the pieces bolted to the crank receive. The tighter the tolerances of that balancing, the smoother and more efficiently the motor will operate. Again, its not so much the hard parts, but the quality of the workmanship that went into to making them all work well together.
Old May 9, 2007 | 06:01 AM
first350's Avatar
first350
I've had mine for more than a yr and about 14K miles...love it, it's not too hard to install. I actually got the whole kit..wanted things to match - the Alt pulley was the hardest to install for me. I've also got UR's flywheel and their new clutch - I love the whole combination...great/real power gains.
-Peter
Old May 9, 2007 | 02:00 PM
G35cTT's Avatar
G35cTT
I just got the UR kit, I'm not sure if it's placebo but feels easier to get going from a dead stop and less chattering on the clutch also. I'm curious if anyone has aftermarket amps using the UR kit?
Old May 9, 2007 | 02:05 PM
Z1 Performance
Former Sponsor
I have the same one on my car (underdriven) with a very power hungry amp (McIntosh) and zero issues
