HKS Circle Earth Grounding (pics)
Old Apr 24, 2003 | 12:53 AM
3kgto's Avatar
3kgto
Default HKS Circle Earth Grounding (pics)
I've got the HKS Circle Earth Red(limited edition but nothing exclusive) grounding kit installed. Immediate observation after the install is clearer audio and HID lamps seems to be slightly brighter (or is it just me).
Don't really feel any difference in engine performance.
Old Apr 24, 2003 | 12:54 AM
3kgto's Avatar
3kgto
before cover replaced
Old Apr 24, 2003 | 12:55 AM
3kgto's Avatar
3kgto
more
3kgto's Avatar
3kgto
another view
Old Apr 24, 2003 | 12:57 AM
3kgto's Avatar
3kgto
under the coolant overflow tank(removed)
Old Apr 24, 2003 | 12:58 AM
3kgto's Avatar
3kgto
cover replaced
3kgto's Avatar
3kgto
another
Old Apr 24, 2003 | 01:00 AM
3kgto's Avatar
3kgto
HKS Earth distributor
3kgto's Avatar
3kgto
last pic
Old Apr 24, 2003 | 01:12 AM
XBS's Avatar
XBS
Veteran
Where do the wires all connect to/ what is it? what does the cover u have over your air filter do? and finally how much did that kit cost, thanks for the info/pics
Old Apr 24, 2003 | 07:03 PM
3kgto's Avatar
3kgto
Hi,
The wires are connected from the different grounding points(I tried to follow as closely to the Nissan's Grounding Kit's points) to a main HKS distribution connector (the black round thing you see) and this distributor itself is linked by a grounding cable directly to the car battery.
I got the universal kit + install for around USD170(converted rates)
The cover on the airfilter is a heat shield and the tip opening is designed to give a ram funnel sort of effect. The shield came with the filter. Its Blitz Sonic Power. Cost around USD200 (not inclusive of piping)
Old Apr 25, 2003 | 06:48 PM
MATIX's Avatar
MATIX
Why do you have the distribution connector connected there, its supposed to be mounted on the negative battery terminal so you have all wires grounding back to the battery.... (see pic below)
Old Apr 25, 2003 | 06:51 PM
MATIX's Avatar
MATIX
like this
Old Apr 25, 2003 | 07:40 PM
ihatethatbobbarker's Avatar
ihatethatbobbarker
ditto
my butt dyno noticed a change in the performance, try wiring it to your batteries negative terminal
Old Apr 25, 2003 | 08:18 PM
3kgto's Avatar
3kgto
like this
Hi,
Yeah, I understand too that it'll be optimum (but not necessary) to put the distributor connector directly onto the battery itself.
But as you know our battery is concealed and if the distributor were to be connected in there, imagine the cluster of grounding cables there and coming out from the rubber cable seal by the battery compartment. The whole engine bay will become very messy. Was trying to strike a balance between show and functionality.
Therefore I decided to be slightly on the losing end of not getting 100% but maybe 90%? by connecting the distributor to the battery directly by another grounding cable.(For info my battery is on the top right where you guy's brake fluid is)
This is why.
Rgds
Old Apr 26, 2003 | 02:56 AM
MATIX's Avatar
MATIX
its actually not messy at all,we installed the HKS earthing kit on hatebobbarkers G35 and it turned out rather nice
Old Apr 26, 2003 | 10:03 PM
3kgto's Avatar
3kgto
Hmm, any pics? If its nice, perhaps I will do something about mine...just hope the cables are long enough to be rerouted, but I highly doubt so.
Old Apr 27, 2003 | 07:00 AM
Ricky's Avatar
Ricky
what kind of intake is that?
performance gains?
price?
work on us version?
Old May 3, 2003 | 12:11 AM
aliali's Avatar
aliali
Hi I'm from asean countries to as you are. May i know which shop you go to buy the HKS product ? maybe i'll go for the shops.
Thanks
Old May 11, 2003 | 03:10 AM
aliali's Avatar
aliali
I installed the HKS grounding kit...the same distributor and I install it different location from you (3ktogo) and I realise not only gaining the Light as you mention but I can feel the the smoothness the engine when rev up. Maybe horsepower increase 1-2
