bluish white smoke
Old May 11, 2007 | 12:56 PM
clipso 01's Avatar
clipso 01
Default bluish white smoke
for the last 2500 miles or so i have been noticing some white smoke coming from my exhaust after deceleration. It only seems to happen after i have been driving for a while. When i come to a stop i get some and then onc ei accel again i get a small cloud and then its gone. Any suggestions?
Old May 11, 2007 | 01:15 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Check your oil on the dipstick. How does the color look?
You might want to send out some oil for analysis and see if there is fuel or coolant in the oil.
http://www.blackstone-labs.com/
Old May 11, 2007 | 01:18 PM
Cannysage's Avatar
Cannysage
did you get a new exhaust?
Old May 12, 2007 | 04:43 AM
clipso 01's Avatar
clipso 01
i changed my oil two weeks ago and it was black but not milky so i doubt that there was water or coolant in it
i added my test pipes around the same time that i started noticing the smoke. i figured that it was just residue burning off but it never went away and that was a few thousand miles ago
Old May 12, 2007 | 05:06 AM
Eazzy's Avatar
Eazzy
The Cats you dropped were doing their job and burning out what ever you are seeing now, Id be curious to see them. Blue is generally an indication of oil. I would do a compression and leakdown first just to see where they are at. How many miles do you have on it ?Keep in mind also that just because you dont have water in your oil dosent mean that there may not be a head gasket problem. Do a pressure chk on your cooling system, including a zero gage reading to see if you get a rise in pressure
Old May 14, 2007 | 05:12 AM
clipso 01's Avatar
clipso 01
how do you do a compression and leakdown test, and about how much would they cost a mechanic to do?
Chris350z03
Oct 8, 2023 07:19 PM
kyin
Oct 15, 2015 05:54 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
