Y-pipe back needed?
Old May 19, 2007 | 03:17 PM
ke0ki2k's Avatar
ke0ki2k
Default Y-pipe back needed?
after readin about several guys who just replaced the cats & y-pipe. if i were to get 2.5 inch test pipes and a 2.5 inch to 3 inch collector Y-pipe, would i need a new Y-back exhaust? ive read that exhausts have proven to give little to nothing in power or torque but several guys ive talked to said that replacing the cats and Y-pipe showed significant gains on dynos. True? not true? discuss.
Old May 20, 2007 | 08:31 AM
Ziggyrama's Avatar
Ziggyrama
Generally, removing cats from the exhaust will improve gas flow. Keeping exhaust gas velocity up is key to making power so I imagine going catless will make additional power. How much? That I am not sure about but I imagine it will be around 10whp +- a few horses depending how restrictive the factory cats were in the first place.
Is 2.5" y-pipe a good size? Seems big for an NA car. Going too big will hurt the flow. I would think 2.25" catless would be more optimal but it's just my gut feeling. If you're FI, no such thing as too big of an exhaust.
Old May 20, 2007 | 08:37 AM
blasian's Avatar
blasian
My friend gained 12whp with his 06. Done on the same day.
Old May 20, 2007 | 08:38 AM
Jim@Showstoppers's Avatar
Jim@Showstoppers
You'll see around a 10whp gain. Although when coupled with an exhaust you will see a bigger gain.
Old May 20, 2007 | 01:52 PM
ke0ki2k's Avatar
ke0ki2k
2.5 inch Y's into a 3 inch collector. how wide is the factory mid pipe?
PLAYDIRTY
Oct 12, 2015 07:45 AM
codek
Sep 27, 2015 03:21 PM
350Shadow
Sep 22, 2015 08:30 AM
