JWT Flywheel and ACT clutch
Old May 25, 2007 | 08:45 PM
mrchu25's Avatar
mrchu25
Default JWT Flywheel and ACT clutch
Thinking of buying a JWT Flywheel and ACT clutch.
Got a question, if i get them will my clutch engagement point change?
I really want a new clutch because I dont like the stock one because the clutch is too high and i tried to lower it but it always goes back up again. Will getting the JWT Flywheel and ACt clutch make it go lower? What else will it change? Thanks.
Old May 25, 2007 | 08:52 PM
Eazzy's Avatar
Eazzy
Maybe ... I like JWT but ACT makes a fine FW----Best to stick with an engineered assy.
Old May 25, 2007 | 08:54 PM
Ninja350Z's Avatar
Ninja350Z
Living in 350Z
I have the ACT HDSS Clutch and the ACT Pro Lite Flywheel, the engagement point is not that much different than stock.
Old May 28, 2007 | 11:35 PM
billybrun's Avatar
billybrun
Have you heard or driven any other light flywheel? Can you compare the noise level?
Old May 29, 2007 | 04:45 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the ACT flywheels are noticeably quieter than the JWT one
Old May 29, 2007 | 05:17 AM
Eazzy's Avatar
Eazzy
I must have screwed up when I installed my JWT, its very quiet, This weekend I will tear it apart and see where I failed---Probably just something simple. >Crossing Fingers<
Old May 29, 2007 | 06:06 AM
Z1 Performance
Former Sponsor
its not that it is obnoxious or anything, but when compared to other lightweight flywheels, it is among the louder ones (the rattle at 2000-2500 rpm). Other flywheels seem to quiet the noise better, some being heavier, some being lighter
Old May 29, 2007 | 06:57 AM
Eazzy's Avatar
Eazzy
Well ---the JWT is 50% lighter and the ACT is 16.9 and 13.2 Lbs. I quess I just adapt to changes and except that a mod of any kind is, as a rule going to have an effect. Your shift points have to change and it becomes the norm after a day. Those that obsess over noises are plaqued by them.
Old May 29, 2007 | 07:01 AM
Eazzy's Avatar
Eazzy
^^^^^ Sarcastic^^^^^
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
