crank pulley help asap
Old May 25, 2007 | 10:38 PM
cleanandquick06's Avatar
cleanandquick06
Default crank pulley help asap
ok, tryin to get the crank pulley off and i need to do it tonight. i cant remember which way the ****in bolt screws off. help please
Old May 26, 2007 | 05:10 AM
DavesZ#3's Avatar
DavesZ#3
Righty tighty, lefty loosey.
If you can't remember the most fundamental rule of fasteners, do you really want to be tearing apart your engine?
Do you have a torque wrench to put the bolt back on with? Do you know how tight to make it? Do you know the special extra step you have to take when tightening it?
Old May 26, 2007 | 05:28 AM
Cube's Avatar
Cube
I've taken off the crank pulley and put it back on atleast 3 times... nothing special. Rightey-tightey, leftey loosey as stated. Maybe he really needs to install an underdrive pulley ASAP.
If you can't get it off, you can put a breaker bar between the ground and the crank bolt and then just crank the engine a couple times.. don't FULLY crank it, just let the starter torque it loose by turning the ignition for like a second.
Old May 26, 2007 | 11:40 PM
cleanandquick06
ok dave, i couldnt remember if it was reverse threaded or not and trust me. i am fully qualified to "tear apart my engine". and dont worry about torque'n it back to specs i cant handle it. its not shiit compared to a f16. now thats a piece of shiit.
Old May 27, 2007 | 08:52 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
If its your first time taking of this particular pulley, prepare for the worst. It is usually tight as hell, and only the most creative approaches can crack that thing off.
It's one of those things looks really easy, but can be a challenging task. Let us know how it goes.
Old May 27, 2007 | 02:25 PM
DavesZ#3's Avatar
DavesZ#3
It's not just "torque'n it back to specs". It's torque+60°.
Old May 28, 2007 | 07:10 AM
Armitage's Avatar
Armitage
Crank pulley bolt is a ***** to get off. According to the UR instructions, someone is supposed to be in the car, shift it into 6th, and slam on the brakes. My friend was able to do it with a breaker bar.
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
