7,845N·m(800kgf) clutch clamping force is equal to what HP?
Old May 27, 2007 | 11:33 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Default 7,845N·m(800kgf) clutch clamping force is equal to what HP?
Hi,
Can someone tell me if 7,845N·m(800kgf) clutch clamping force can handle 550~600WHP? This is the spec for the nismo twin clutch by the way.
Thanks in advance.
Old May 29, 2007 | 04:48 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
no - the twins cerametallic units, like NISMO, are good to about 475-500 whp in my experience and the associated torque levels
to hold that power you will need a triple disk carbon from the likes of ATS/Carbonetics
Old May 29, 2007 | 05:11 AM
doublins's Avatar
doublins
Originally Posted by leeboyNY
Hi,
Thanks in advance.
HP has nothing to do with it- torque is all you need to be concerned about. And on that note, you'd have to do some math using the contact area, frictional coefficients (both static and dynamic), detailed diagrams of the flywheel, clutch, and pressure plate assemblies, yada yada, to even get close to a theoretical number. All clamping force tells you is the Normal force applied to the clutch assembly, of which the frictional force (force preventing clutch slippage) is a factor. You need a lot more info that to come up with your answer.
-C
sherm
Apr 11, 2020 05:21 PM
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
