Adjusting a nismo lsd????
Old May 31, 2007 | 06:07 AM
saberphx's Avatar
saberphx
Question Adjusting a nismo lsd????
Hey guys can someone explain to me how to adjust the lok percentage on a nismo lsd? Also how do you switch 2 way to 1.5? Yes i've searched but haven't found anything explaining how in detail. Hoping to fnd out today so I can adjust if need be while my car is in the shop. Also I was thinking to set it at 60% lock, my car is a semi daily driver but I prefer performance over drivability. Sound good?
Thanks for any help guys!
Old May 31, 2007 | 06:31 AM
Motormouth's Avatar
Motormouth
hit it with a hammer really hard or call it names.
'hey fatty, why don't you have 80% lock up? huh chubby?'
that gets results.
Old May 31, 2007 | 06:32 AM
Motormouth's Avatar
Motormouth
everyone with a Nismo LSD I know (me included) leaves it at 60% lockup, the lowest.
changing lockup (or is it preload? not sure) you slide the stub axle off and use a socket wrench. I have instructions somewhere if you need them and no one else chimes in... they came with the LSD.
and to switch from 1.5 to 2 way you need to open it and rearrange the clutch plates I believe.
Old May 31, 2007 | 07:39 AM
saberphx's Avatar
saberphx
Thanks a lot bud! If the diff comes already set to 60% then I should be good, I appreciate your reply.
Old May 31, 2007 | 07:58 AM
vaughn1576's Avatar
vaughn1576
My Nismo LSD came set to the middle setting (I forget the amount of lock-up). I had to have it adjusted to 60% myself, and that's still aggressive for the street.
nanotech
Oct 2, 2015 05:02 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
