Problem shifting into first???
Old Jun 7, 2007 | 09:51 AM
Phenom's Avatar
Phenom
Toasty
Default Problem shifting into first???
This happened a couple times and I'm not sure if this is a common problem for others. Basically, when I'm slowing down approaching a red light or stop sign, I usually downshift until third, then press the clutch down and coast to the light/sign. If it's a light, I put it in neutral while I coast, when I'm coasting to a stop sign, I put it in first while holding the clutch, then come to a stop with the clutch down the whole time.
One time when I had the clutch down and went to put it in first, there was a loud grinding sound so I quickly pulled it back to the neutral position (the clutch was held down the entire time). I can reproduce the problem 100% of the time. It seems whenever I'm going over about 20 mph and press the clutch and trying puting it in first it does the same thing. Even if I try puting it into the first position a little I can feel shifter start to rattle. I have an 07 with about 700 miles on it. Anyone know whats going on?
Old Jun 7, 2007 | 09:55 AM
Ztalker's Avatar
Ztalker
may i ask where did you learn to drive a stick shift?
Old Jun 7, 2007 | 10:01 AM
What is with all this coasting in neutral?
Where does this technique come from?
Old Jun 7, 2007 | 10:04 AM
ArCtM's Avatar
ArCtM
rolling at 20mph you should go into second.
Old Jun 7, 2007 | 10:09 AM
NGZ's Avatar
NGZ
Or at least rev match to get 1st in.
Old Jun 7, 2007 | 10:24 AM
rockinbboy's Avatar
rockinbboy
Yeah you are going too fast to throw into 1st..so thats why you got that grinding. I never throw the car into first unless I am going like under 6-8 mph. I love that digital speedo. I don't know what I'd do without it
If you really want to put it in 1st...double clutch. That is. clutch in..shift to neutral..clutch out. then clutch in again to shift to first...but like NGZ said...rev match it.
Old Jun 7, 2007 | 10:26 AM
The Brickyard Rat's Avatar
The Brickyard Rat
You should not be putting into first gear at 20 or so MPH. Best if stopped completely but not more than 5 MPH is my experience.
Old Jun 7, 2007 | 10:34 AM
350XTCz's Avatar
350XTCz
I never downshift to 1st. I only go into first from a stop. However, as Brickyard Rat said, if you must shift into 1st, do so below 5 mph.
Old Jun 7, 2007 | 12:11 PM
Phenom's Avatar
Phenom
Toasty
Maybe I worded the question poorly. I never intend on taking my foot off the clutch until I come to a complete stop. What I'd like to do is
-Clutch in
-Select first
-Brake until competely stopped (clutch still pressed down)
-Clutch out and accelerate
So really I'm not trying to shift into first while slowing down, I just want to select first with the clutch pressed down to have it ready for when I went to release the clutch and accelerate once I've stopped.
So, that being said, I'm confused as to why it would grind if I have the clutch pressed down completely while selecting first.
Thanks
Old Jun 7, 2007 | 12:22 PM
ArCtM's Avatar
ArCtM
Oh I understood it as you trying to down shift into 1st. I have no idea what your problem could be but if it is easily duplicated take it to the dealer.
Old Jun 7, 2007 | 12:41 PM
cheshirecat79's Avatar
cheshirecat79
Don't shift into first if you are going faster than 10 miles an hour, even if the clutch is in.
I could be wrong but doesn't this have something to do with the first gear syncro?
Rob
Old Jun 7, 2007 | 01:09 PM
tranceformer95's Avatar
tranceformer95
Uhhh, i never downshift into first unless i'm at a dead stop or maybe less than 5mph.
Old Jun 7, 2007 | 01:12 PM
The Brickyard Rat
I'm not the tech guy here but I believe the MT is set so you can't go into first, even with clutch in, until at or near a complete stop.
LAKERSFAN's Avatar
LAKERSFAN
doesnt matter if you have your clutch engaged or not my man. only go into first after youre at a complete stop. or at the very least, under 5mph.
Old Jun 7, 2007 | 01:14 PM
Kolia's Avatar
Kolia
-Clutch in
-Select first
Thanks
Did you know that the transmission is spinning whenever the car is in mouvement? The clutch only separates the engine from the transmisison. But the wheels are always making the transmisison spin.
Engine - Clutch - Transmission - shaft -wheel - road
So you're grinding because you're trying to get the first gear in while still moving too fast. Don't do that to your new car please. You absolutely need to double clutch to get that gear in at such speeds.
Unless things have changed in '07, first gear has only a double synhro while second has a triple. Second is always easier to shift into.
Old Jun 7, 2007 | 01:40 PM
highside107's Avatar
highside107
Yeah, I have this "problem" too, so it's not just your Z. As Brickyard has said, only shift into 1st if going at 5mph or slower. Anything else, 2nd gear is good enough for.
Old Jun 7, 2007 | 09:14 PM
Phenom's Avatar
Phenom
Toasty
Thanks for the help everyone. Sorry, I've only been driving a manual for a couple weeks now. I've only caused it to grind twice so far, both were like I said, trying to put it into first while moving too fast, but I'll never make that mistake again. I'll be careful not to hurt my car anymore
Old Jun 7, 2007 | 09:21 PM
Ztalker's Avatar
Ztalker
also try not to shift into 1st if your car is rolling back.
Old Jun 8, 2007 | 03:42 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
+1 ...
you can't get it into 1st @ more than ~5mph unless you rev match the enigine / transmission speeds
Old Jun 8, 2007 | 04:30 PM
LG_z33's Avatar
LG_z33
Best to just not shift into first unless from a dead stop.
