attn: engine builders.....best valve spring compressor???
Old Jun 18, 2007 | 04:46 AM
QuadCam's Avatar
QuadCam
Default attn: engine builders.....best valve spring compressor???
who makes a nice valve spring compressor for the VQ heads? they show a fulcrum style one in the service manual...
what are you using?
Thanks,
Andrew
Old Jun 18, 2007 | 06:23 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
We have the fulcrum style that we use on the bench occassionally. But by far, the best/easier one looks like a medium sized metal flashlight. It has a magnetic tip, and you simple push. I dont have the PN or brand handy, but any tool truck should carry one. Jeremy should have one of these two types...ask him what he uses.
Old Jun 18, 2007 | 09:37 AM
QuadCam's Avatar
QuadCam
Sharif,
are talking about one of these?
these are good for removing the locks, but are not the easiest for installing them.
Old Jun 18, 2007 | 10:02 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
thanks, i actually use a tooth brush and a butter knife... they work just fine
Old Jun 18, 2007 | 10:11 AM
MardiGrasMax's Avatar
MardiGrasMax
When I did my VQ30 heads I used a fulcrum style, the first few were a PIA. One of the things I did to protect the lifter bores in the head was, I took two old lifters and cut the tops off, then and deburred the cut real good. Then slid them in the lifter bore. This way if I slipped with the compressor I wouldnt srcatch the bore.
Old Jun 18, 2007 | 10:20 AM
overZealous1's Avatar
overZealous1
i made one out of aluminum bar stock. it hooks under the cam saddle bolt, then a washer welded onto a couple stand-offs that compress the spring at the correct fulcrum point. polished the edges smooth on the washer to keep from scratching the bore.
sounds complex, but it took about 10-15 minutes to make and had the parts to make it laying around, lol.
can send a pic if you really want.
Old Jun 18, 2007 | 10:26 AM
QuadCam's Avatar
QuadCam
wanna make another one?
Old Jun 18, 2007 | 11:17 AM
Sharif@Forged
Forged Performance
Originally Posted by QuadCam
Sharif,
That's the one. Very very easy to reinstall as well. Are you planning on doing this on a bench, or while the engine is in the car. Let me know.
Old Jun 18, 2007 | 11:18 AM
Sharif@Forged
Forged Performance
Care to demonstrate?
Old Jun 18, 2007 | 11:40 AM
QuadCam's Avatar
QuadCam
on a bench.
Old Jun 18, 2007 | 03:34 PM
Sharif@Forged
Forged Performance
on a bench.
Very easy to do. Just stuff a balled up rag under the valves, and push down firmly with the tool.
Old Jun 18, 2007 | 07:11 PM
QuadCam's Avatar
QuadCam
the valve springs on these engines are that soft? I haven't even checked them....I am used to the springs used on OHV V8s
Old Jun 19, 2007 | 06:08 AM
Sharif@Forged
Forged Performance
LOL...no...you have to put some **** into it. I just use my body, and lean into the thing. You can do it!!
Old Jun 19, 2007 | 07:30 AM
overZealous1
not sure i have any extra material to make another, i can check, but time is really not on my side right now. i am assembling some heads right now and need it, but may be able to loan it to ya if you run out of options.
Old Jun 19, 2007 | 07:34 AM
overZealous1
ya, seat pressure is only about 35-40lbs (iirc) no 100+lbs seat pressure like V-8's, lol. i can open the valves by pushing on them with my thumbs! that is why i had concern early in the VQ35 boosting stage about high boost levels overcoming some of the seat pressure helping in valve float at higher rpms. seems no one has had a prob with it though.
Old Jun 19, 2007 | 07:49 AM
Eazzy's Avatar
Eazzy
The Nissan one is a KV10115900 which is a KV # I believe ( KV is a company that has been making Service tools for yrs for special applications) I think that # is Nissan J26336-20
But I have always fabed my own ---There is the Falcrum which is handy for removal of the springs on a pressurized installed head or any # of universal C-clamp types for bench work.
BTW....Off subject, but on reinstallation of the keepers always make sure you have the same spacing on both sides of the half moon so one does not touch the other. Just a little thing, and one in a thousand, but have seen a time or two that at High RPMs, the keepers being spit out due to interfereance
Old Jun 19, 2007 | 07:59 AM
QuadCam's Avatar
QuadCam
LOL...no...you have to put some **** into it. You can do it!!
Are you making fun of my big a$$?
Old Jun 19, 2007 | 08:11 AM
Kenk2's Avatar
Kenk2
Professional
Being an Aluminum Company we have all kinds of barstock here.. Send me a few pics, maybe with some measurements and I can have 1 made in a day or so..
Old Jun 19, 2007 | 06:37 PM
QuadCam's Avatar
QuadCam
I went ahead and ordered the snap-on piece that Sharif was recommending........
in the mean time, I removed apair of the exhaust valves using my own technique......
place a 17mm socket on the retainer. use a 6" extension on the socket....... give it a solid whack on the end of the extension with a mallet.......the result is that the keepers pop right out!
Old Jun 19, 2007 | 06:40 PM
Sharif@Forged
Forged Performance
Removal is a snap....we dont even use the tool. It's reinstall that will be a dream with this tool. How did you end up paying for it?
Remember...breathe....lean...release.
