"Clutch Shudder" question
Old Jun 22, 2007 | 12:47 PM
T_R_J's Avatar
T_R_J
Default "Clutch Shudder" question
I'm wondering if anyone has experienced this issue regularly like I have and if they found a way to fix it.
I've got an '06 with roughly 19k on it, when I let out the clutch at a low RPM the entire car will shudder. The engine isn't dying, as I'm around 12-1500 RPM. I spoke to a mechanic at my dealership and he suggested it was just slack being picked up in the rear diff but that doesn't make much sense to me.
Anyone else experience this?
Thanks!
Old Jun 24, 2007 | 09:34 AM
jaxredz's Avatar
jaxredz
yes....I have an 06 and have experienced the same "shudder"....a coworker has the same car and has experienced the same thing.....I have just assumed they all do it.....and decided theres nothing that can be done.....I think I mentioned it to the dealer once and of course nothing ever happened....I have just decided to live with it and give it more gas....it does really annoy me at times...
Old Jun 24, 2007 | 10:35 AM
dmroberson's Avatar
dmroberson
I've noticed it, from time to time, but I don't think much of it, since it happens so infrequently.
Old Jun 24, 2007 | 06:26 PM
AmateuRN's Avatar
AmateuRN
Kinda off topic... but my '02 MR2 does it the first half dozen or so times when cold.
Old Jun 24, 2007 | 06:32 PM
Billhyco's Avatar
Billhyco
we can chalk it up with the throw out bearing like noise. Even the G's have that. Or so my buddies 06 Sedan does anyhow.
Old Jun 24, 2007 | 06:33 PM
cheesewedge's Avatar
cheesewedge
My '06 doesn't "shudder" when starting off but it does kind of "hiccup" when letting out the clutch from 1st to 2nd gear. It annoys the heck out of me. I've never had such a touchy manual trans car before.
Old Jun 24, 2007 | 06:34 PM
Eazzy's Avatar
Eazzy
If after several 1000 miles you start to get a shutter, Then there is something out of wack in the pressure Plate, like a "out of square" release because of a bad diaphram or a pilot bearing that went bad----Nothing will help it other than taking it apart and inspecting it, and if you do that , you mite as well replace it or upgrade
Old Jun 24, 2007 | 09:00 PM
philude's Avatar
philude
mine makes noise too...sounds like the same rattle i hear when i turn my car off.
Old Jun 25, 2007 | 07:15 AM
gothchick's Avatar
gothchick
My '06 does it about 30% of the time.... I had an '04 prior to my '06, it did it too...
Old Jun 25, 2007 | 07:49 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Here's what's happening that makes the whole car shudder: the clutch is slipping, then grabbing, slipping, then grabbing, on the drivetrain. This causes the whole car to vibrate violently.
YES..........I've had this problem and I now know there are 2 things you can do about this.
1: Launch using higher RPM.
2: Replace differential fluid. Your car is having higher rolling resistance when it's at a stop due to dirty diff fluid. Replace it and I guarantee your car will launch easier at lower RPM. I know it sounds kinda weird, but I promise you, it will help GREATLY.
By doing these 2 things you can basically eliminate this problem. Much cheaper than buying a new clutch, which is what I **almost** did.
Old Jun 25, 2007 | 08:20 AM
LandonZ's Avatar
LandonZ
So, would you suggest using the Royal Purple gear oil? Sometimes I have heard that Royal Purple may not be the best idea in some cases?
Old Jun 25, 2007 | 10:16 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I used redline 75W-90 with limited slip additive. I've been happy with it but I think my diff is full of shavings again, and I will probably change the fluid again.
Old Jun 25, 2007 | 02:46 PM
Behemel's Avatar
Behemel
Yup, I've had this problem too. Adjust your shifting habits and you can learn to avoid it.
+1 for Wired 24/7 and you can avoid the issue even better.
Old Jun 25, 2007 | 02:52 PM
ohSIXz's Avatar
ohSIXz
hmm. never had this problem in my 06. ill keep an eye out tho!
the sound when you turn off yer car is the timing chain i believe.
Old Jun 27, 2007 | 06:57 AM
motorheadrr's Avatar
motorheadrr
I have experenced the shudder since day one. I have 4600 miles on the car now. I have an appointment with a tech at nissan tomorrow morning to have him look at it. I will keep you guy posted.
Old Jun 27, 2007 | 09:02 AM
LandonZ's Avatar
LandonZ
I will try to stay away from the stealerships as much as possible.. Ill try changing the oil to royal purple and see what happens after that
Old Jun 27, 2007 | 09:40 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Or you could just read what I posted, because I'm right, and when you go to your dealership they will tell you "nothing is wrong", because technically, nothing is wrong.
Old Feb 12, 2020 | 04:20 PM
Karl Lee's Avatar
Karl Lee
Default Clutch Shudder — I replace my differential fluid with 80w90 Penzoil differential
I replace my Differential fluid today 80w90 GL-5
pennzoil ...... the shudder is gone away .... total cost of 2 quarts of fluid $19.00 it take 1.5 quarts ...... easy DIY job ...... unbelievable...... the car is much stronger ...... changed the transmission fluid with Nissan fluid GL-4 ..... all issues with suddering is history ....gonna change differential annually now ..... 2003 350z 172,000 miles ....... orginial clutch/transmission/differential
sherm
Apr 11, 2020 05:21 PM
issyz
Jul 2, 2017 03:04 PM
