Rear main seal..
Old Jul 16, 2007 | 10:10 AM
ZCor's Avatar
ZCor
Default Rear main seal..
Ok so i went today and got the oil changed on the Z it had been freakin me out with the small oil leak..Its comin from the bell housing and the tranny. So when i got my oil changed today they told me it was my rear main seal...i do NOT have a warranty on the car.. so how much you think im lookin at to get the seal replaced stuff? thanks alot guys
Corey
Old Jul 16, 2007 | 12:22 PM
TENGAI's Avatar
TENGAI
Wow. Don't know. Get a quote and make sure to post up. I'm curious what a dealership would charge for this.
Old Jul 16, 2007 | 12:47 PM
ZCor's Avatar
ZCor
Im not goin to take it to the dealer to get it fixed...my buddy owns a transmission shop, and my other friend is gettn a new clutch put in his 350, so im goin to have him put in the new seal and see how much he would charge to do it all im sure it will be ALOT cheaper than stealership...
Old Jul 16, 2007 | 12:54 PM
westpak's Avatar
westpak
SFZCC
It would be similar to the time required to replace the flywheel plus an hour or so for the removal of the rear seal, cleaning of the area to remove RTV and reinstall of the new seal.
Old Jul 16, 2007 | 03:09 PM
MDeezy's Avatar
MDeezy
check the type of fluid leaking.
I have a leak that I thought was my rear main seal but it turns out its gear fluid. if it was a rear main leak it would be engine oil leaking.
Old Jul 16, 2007 | 05:15 PM
ZCor's Avatar
ZCor
im pretty darn sure its engine oil...whats the gear fluid look like...this thats leaking is dark thick like oil...
Old Jul 17, 2007 | 06:07 AM
Q45tech's Avatar
Q45tech
Common to get rear main seal leaks as engine age and blow by increases.
Do you park overnight flat or on an incline?
Old Jul 17, 2007 | 06:32 AM
AMF's Avatar
AMF
I currently have this same leak and the dealership verbally quoted me $800. But, at least they are giving me a loaner car to beat on for the day.
Old Jul 17, 2007 | 09:59 AM
ZCor's Avatar
ZCor
i park flat in my garage, my 03 Z only has 23k miles on her
Old Jul 17, 2007 | 11:58 AM
ZCor's Avatar
ZCor
Well i went to a shop today thats well knows for their great tranny work...they quoted my 300 for labor and 32.95 for the rear main from nissan.. does the cost of the rear main sound right?!
Old Jul 18, 2007 | 08:46 AM
ZCor's Avatar
ZCor
hows that price sound to everyone else?
Old Jul 18, 2007 | 08:49 AM
westpak's Avatar
westpak
SFZCC
That is a good deal, I would take it.
Old Jul 18, 2007 | 09:32 AM
ZCor's Avatar
ZCor
well, the car goes into the shop next week to get it put in.
Old Jul 18, 2007 | 11:00 AM
JFAIR's Avatar
JFAIR
I had the rear main oil seal replaced on a 2000 saturn. it was 300.00 in labor and like 15.00 for the part. vehicle wasn't a z but now you got some $ figures.
Old Jul 19, 2007 | 01:14 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Get a second opinion, sounds like a possible dealer BS story to me.
Old Jul 19, 2007 | 04:49 PM
go-fast's Avatar
go-fast
the vq rear main comes with the aluminum plate from nissan wich mates with the oil pan, the right way to change the part is to also drop the pan because during assembly the rear main goes on before the pan ,i have cheated them before but it's not easy.you either have to pop the new seal out of the new plate without damage and install in the old plate or trim the oil pan to rear main seal and lever the new plate in ...niether are very attractive but neither is dropping the pan!
