Is Motul RBF-600 okay for clutch fluid?
Old Sep 12, 2007 | 12:58 PM
redlude97's Avatar
redlude97
Originally Posted by gocart
"Best of all worlds"? I don't understand... isn't water-absorption an UNdesirable trait?
They said water absorbing characteristics, which could mean its resistance to such
Old Sep 12, 2007 | 01:22 PM
THX723's Avatar
THX723
Some water absorbing characteristic is actually desirable for non-race use, where the hydraulic fluid is not expected to be replaced on a daily basis. The hygroscopic-ness is necessary to "absorb" and disburse/diffuse the water that found its way inside the hydraulic line (and they do), where accumulation can sometimes occur, a serioius safety hazard in area where below freezing temperature is a common occurance.
Old Sep 12, 2007 | 03:44 PM
mthreat's Avatar
mthreat
I ended up using some Valvoline fluid instead of Motul, so I don't have to change it so often. It's been working fine with the heat from the headers.
Old Sep 12, 2007 | 05:27 PM
redlude97's Avatar
redlude97
I would flush it every other oil change, or whenever the fluid begins to get cloudy also, its so cheap to do anyways
Old Feb 16, 2008 | 11:31 AM
jmark's Avatar
jmark
Originally Posted by Sharif@Forged
We use it all the time with brakes and clutch....good to go.
Shariff, I hear you sell Motul RBF-600. Any discounts for my350z members? PM me a price shipped to 29651, Greer SC. I need a bottle when I have my clutch slave cylinder replacement done. Thanks!
Old Feb 27, 2008 | 04:10 AM
jining's Avatar
jining
So... how much brake fluid does one need when flushing? (Never done it before)
Old Feb 27, 2008 | 05:20 AM
jonnylaw's Avatar
jonnylaw
3 bottles of rbf600
Old Feb 27, 2008 | 05:55 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Amsoil also has the new line of Dot 3 and Dot 4 fluids just a FYI.
Old Feb 27, 2008 | 12:09 PM
warmmilk's Avatar
warmmilk
has anyone tried neo synthetics brake fluid before?
it has the highest dry and wet boiling point i've seen in any brake fluid at 610 dry and 421 wet
http://www.bakerprecision.com/neobrk.htm
Old Feb 27, 2008 | 12:13 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
its all marketing hype anyway unless you are running at LeMans, it would be a waste. Even a decent fluid should easily be able to cope with anything any of us are realistically doing with our cars
Old Feb 27, 2008 | 12:18 PM
warmmilk's Avatar
warmmilk
marketing hype as in it boils at lower points, or marketing hype as in i don't need something with such a high boiling point?
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
