oil consumption = no modding
I would have a working relationship [developed in advance] with one Master Tech who volunteers to do all your work [a precut deal]............the tech tells the service writer/manager he is your cousin in law or some such bunk. wink wink.
Why people who visit one dealer every 90 days for oil changes and warranty repairs get to know who is who.
Just being JOE BLOW off the street, [first visit] and attempting to bribe people doesn't usually work................ could be a setup is the first thought in the techs mind.
Vehicle cost is the 2nd most expensive item per month for most yet it is treated withOUT forthought and optimization.
hey man i was kidding about the tip. i do all my own work. .recall or not i have parts connections. .so i'll never take my car to the dealer. .unless i absoluuuuuutely have to!! in fact i took my z for the tire feathering recall at 20k. .and got a call mid afternoon about my car needing a tune up servicing. .i chuckled at the guy. .
Originally Posted by DraGonAlchemist
look everyone keeps saying oil consumption. .but has anyone noticed where the oils going?. .is the car burning the oil? (blue smoke from exhaust) is the car loosing oil, like does anyone see spots or dripping if they park it same spots?. .reason i ask is cause older Benz's say 92-98 always have a rear head gasket leak external. .so oil comes out not antifreeze. and its very minimal to maybe a qt loss for every few months depending. ..and my ? is if you guys can pin point yourselves the problem or symptoms that may look like the cause would be great. .
Originally Posted by go-fast
it's the low tension oil rings that were used and it blows out the tail pipe.it is a fairly new trend among all automakers to increase fuel economy by reducing reciprocating friction.
Thats really sad, i wonder how they are gonna build the GTR. I have a 04 titan and ive had so many problems with it thats not even funny. All nissan does is replace the bad part with another bad part, they dont find the problem/source of the problem and fix it for good, terrible quality controll from nissan and guess what this will back fire at them.
In my case the oil ends up coming out of the exhaust tip. I have never seen any smoke of any color ever but I know that's where it goes, because the tips turn black sometimes after about a dozen miles. Sometimes I can drive 200 miles and they stay clean other times they may turn black after 5 miles. It's very irratic. Does not drip a drop and it's not burning off on the exhasut or I would smell it.
I've had an oil catch can on for a year and have had to add 4 quarts or so of oil in 12 months and there is maybe a teaspoon of crap in the can at the most, if any. I haven't got around to checking the actuall level because I'm too lazy to remove it.
hmm. .well i do hope that whoever gets an engine swap they also take care of your cats as well. .being gunked up with oil im sure an engine lights bound to pop up at any time for catalytic threshold efficiency deterioration...
i think im going to trade it in i cant deal with all these hoops they got me jumping to get a swap i want a car from the factory not one where the engine was riped out then another one put in im searching for a 07 / 08 nismo z i guess lol no smoke out my tail pipe tho...
i just had mine changed 2months ago and i have about 4 k on it too early to tell. But when i bought the car new it was eating up oil about 1QT since day one and the oil was super black by 2K (Mobil 1 SYN btw ). with this new long block that is not the case.NO PROBLEMS UNTIL NOW KNOCK ON WOOD LOL
nissan specs the same rings on the 287 compared to the revup motors. The only difference I have seen is nissan uses a very tight ring gap on the 2nd ring in the revup motors. They run the same gap as the top ring. on the 287, the second ring runs a significantly wider gap than the top ring.
This could definately be the problem. without an easier way for blow-by gases to get down past the second ring, these gases can go back upward toward the top ring....causing ring flutter and sucking oil upward past the top ring and into the combustion chamber.
Mine doesn't consume enough oil to be covered by the TSB... I get barely a tea spoon worth in my catch can after a week or two of driving. But it is still consuming. I love this car, so I'm getting ready to do a complete build on the lower end, and head work/ cams. 300+ whp is my goal.
Originally Posted by Q45tech
N=
A smart move is to tip the tech when ever warranty work is done to try to make up some of the money he loses don't tip the service writer or dealership it won't help the guy who is doing the real work.
On a 15 hour job the tech is losing 5 x $25 =$125 adjust for taxes and $100 really speaks VERY loudly! Heck $50 shows you understand the working guy.
I do understand the "working guy", but a tip?....
We (rev-up owners) are the ones who paid good money for a faulty engine... Nissan should be tipping us.
To me oil is $2 per quart and if you add 1 quart per 1000 miles thats only $200 per 100,000 miles, hardly worth getting excited about. Considering the gasoline will cost over $17,000 in that period and use, insurance, tag, tax, interest,depreciation will be $55,000.
I buy all my oil by the case or 200 gallons at a time.
Even 1 quart every 250 miles won't be $800 over 5 years.
The bottom line is, these engines should not be loosing oil.
Honestly. Im not conerned about the fact that im losing oil. Should it? No. Does it annoy me cleanig soot off my rear bumper? Yes..
But
My biggest thing is if your gettin blow by. Your probably also not putting down the power the engine is suppose to.
But
I understand where Q45Tech is coming from on the Tip thing. But honestly.. Do you really expect a pissed off customer whos made 10 trips to the dealership to still not have the problem fixed with no immediate solution.. On the biggest part of the car (the engine) with no reimbursments for your time..
You really expect them to tip? If the waiter told you to hurry the f*ck up and order then rubbed your steak on his genetles would you be tipping?
