100 Shot Direct-Port?
Old May 16, 2003 | 07:17 AM
TheBigShow's Avatar
TheBigShow
Default 100 Shot Direct-Port?
got some nitrous q's, guys. i'm not too knowledgeable about the z after the throttle body. could someone explain to me how to install a direct port kit? it was easy to understand on my honda with the intake manifold's 4 runners easily visible. i would assume the z has something similar. does anyone have pre-drilled manifolds for direct-port setups?
now i know quite a bit about nitrous in general, but i also have some questions about what u guys r doin for your 100 shot cars: fuel pump, fuel pressure regulator, clutch, motor mounts, ignition retard? i know plugs r a must; i'm just curious about how the other components in the z handle the juice. thanks.
Old May 16, 2003 | 01:24 PM
UnderPressure's Avatar
UnderPressure
It's not easy.
(hint)
Old May 16, 2003 | 07:40 PM
eskimo's Avatar
eskimo
Originally posted by UnderPressure
It's not easy.
(hint)
Did you get a direct-port set up going like you were planning?
Old May 16, 2003 | 11:04 PM
UnderPressure
Come to car-wars sunday and find out.
Old May 17, 2003 | 12:18 AM
12SecZ's Avatar
12SecZ
depends on the Kit,
Per Zex since the fule is controlled by the bottle a bigger pump isn't necassary, can't hurt but my car gets plenty of fuel with the 100 shot and ZEX.
NOS is the only one I know making direct port and $1300+ seems like an aweful lot for a 100 shot.
Old May 18, 2003 | 12:22 AM
M3This's Avatar
M3This
I would say call Nitrous Oxide Systems and ask about their injector clip systems ( the ones where the nozzels clip in by the stock injectors and there is no need to drill holes) as that would be your best bet if they make it so it would fit the Z. Other wise just have someone from a shop with a LOT of nitrous experiance do the install............trust me the money is worth it! ......The z isnt a honda, as I too use to be into hondas, and blowing up a Honda motor isnt that expensive, but not doing a proper install on the Z and runnign lean is costly!
Old May 18, 2003 | 07:41 PM
TheBigShow's Avatar
TheBigShow
is there any 350 specific nitrous apps out there? i can't find any. i have awhile though, since i plan on doin everything else before. can anyone answer me on my fuel and ignition concerns?
Old May 19, 2003 | 11:09 AM
12SecZ's Avatar
12SecZ
If you want direct port I would wait before drilling one will come out if not out already.
The car runs rich N/A with a 100 shot it's close.
Better rich than lean but you could gain one tenth by leaning out the fuel on N20 (10HP)
I personally don't think you will need a fuel pump with a 100 shot.
If someone trys to sell you one then they just want money, I haven't needed it.
If you do that why not go all the way and get bigger injectors?
Woot!
Sounds like money is not an issue for you.
Old May 19, 2003 | 06:36 PM
eskimo's Avatar
eskimo
Sorry I missed it, I was at work, maybe I'll catch you some day though.
Old May 19, 2003 | 06:56 PM
TheBigShow's Avatar
TheBigShow
when did zex start sellin wet kits? i know about a year or so ago, we always made fun of zex cause they were strictly dry and advertised gains at the crank. i'm glad they r startin to get with it though. do they actually recommend a 100 shot with a single fogger setup? i know a 75 was limit on the honduh, and i realize that is a totally different animal; just curious.
sales@czp
Sep 23, 2019 03:30 PM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
Mattg350z
Oct 2, 2015 06:51 AM
SharX59
Sep 27, 2015 09:23 AM
