Engine Rust?
Old Aug 31, 2007 | 04:59 PM
bremboboy's Avatar
bremboboy
Default Engine Rust?
Hey guys i was cleaning out the engine bay today and I noticed this rust on the engine. What part is this? and is it normal?
Thanks
Old Aug 31, 2007 | 05:07 PM
Kevins350z's Avatar
Kevins350z
lol that sux man....take it back to your dealer and have it checked out
Old Aug 31, 2007 | 05:14 PM
bremboboy's Avatar
bremboboy
i dont trust the dealer....you guys are better!
MagicPie's Avatar
MagicPie
From the picture, its just a hose clamp, clean off the rust if it bothers you.
I would guess some water settled on it from a dealer cleaning it or you cleaning it.
That clamp just happen to not have enough of the coating sprayed on it to prevent rust, they're just cheap clamps after all.
Removing the clamp and hose, you will see a brass nibble-- that will not rust, so I there is no real concern about a problem
I would just clean the clamp and surrounding areas, and keep a eye on it from time to time
I cant say its normal, but its hardly a real issue, and not entirely uncommon to see.
Old Aug 31, 2007 | 05:20 PM
bremboboy's Avatar
bremboboy
thanks...
Old Aug 31, 2007 | 05:25 PM
jimmyloose's Avatar
jimmyloose
It doesn't look like rust to me. Drain a little coolant out, disconnect the hose and clean it. Shouldn't be a real issue.
Old Aug 31, 2007 | 05:27 PM
MagicPie's Avatar
MagicPie
Looks like surface rust, from the residue that came off the clamp. Its not actually rust and/or rusting
I wouldnt think the plenum would be the source of the rust, but if you want to make sure, you can safely and easily pull back the clamp and pull off the hose.
You should be able to clean the area much easier and get some piece of mind, that its only a cheap clamp and not the plenum.
To me its no big deal
Old Aug 31, 2007 | 06:21 PM
bremboboy's Avatar
bremboboy
do you think the dealer will replace that clamp and clean off that rust under warranty?
Old Aug 31, 2007 | 06:24 PM
sluggoZ's Avatar
sluggoZ
Yes!
Old Aug 31, 2007 | 06:32 PM
MagicPie's Avatar
MagicPie
Just yell and complain til they do
Seriously for a 7 month old car, it shouldnt of happen, the dealer should take care of it for you.
Old Aug 31, 2007 | 06:56 PM
bremboboy's Avatar
bremboboy
ok
Old Aug 31, 2007 | 07:27 PM
Z04's Avatar
Z04
isn't the upper phlenum aluminum? if that is the case then it will not rust. wipe it off and get that clamp changed, all should be ok.
Old Aug 31, 2007 | 08:45 PM
dTor's Avatar
dTor
Old Aug 31, 2007 | 08:50 PM
UnderPressure's Avatar
UnderPressure
Oil reside from the crankcase breather tube. Not rust. Have the dealership check it out, shouldn't be that much blow-by for a relatively new engine.
Old Aug 31, 2007 | 09:01 PM
bremboboy's Avatar
bremboboy
thanks for the response
Old Sep 1, 2007 | 06:01 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
...that's not rust, it's a breather tube. Nothing to "give them hell about" - get some simple green and a toothbrush and clean it off
Old Sep 1, 2007 | 08:52 AM
My god that's horrible. Time to trade it in.
Old Sep 1, 2007 | 10:51 AM
bremboboy's Avatar
bremboboy
wtf?!?!^^^^^
Old Sep 1, 2007 | 12:01 PM
Resolute's Avatar
Resolute
No kidding.
bremboboy, I thought you might be joking. Why would you "give them hell" at the dealership over something so small? Have you even tried to just scrub it off with a brush, or wipe it with some steel wool? A can of WD40 would make it easy to clean off, even if it was just rust. Chalk the cleaning up to maintenance if it bothers you so much. It's not a defect. I am surprised that you would even consider going to the dealership for something so small than can be taken care of yourself.
It's sarcasm, bremboboy. It strikes some as rediculous that you would be this bothered by brown discoloration on your manifold. It's nothing. Just clean it off and replace the hose clamp with a screw-drive clamp from any auto parts store. This way you can clamp it down and be sure it's tight. Or, just leave it alone- your engine will be fine. If you go to the dealership with this, they may well (and I think rightly so) laugh at you.
Will
Old Sep 1, 2007 | 02:08 PM
failsafe306's Avatar
failsafe306
Take it to the dealer and "raise hell", but bring a friend with a vid camera
I wanna see this.
