**** 4.083 Gears/Final Drive Installed****
Old Mar 25, 2011 | 04:39 PM
  #741
PolePosition's Avatar
PolePosition
Default Lighter flywheel combined with 4.083 gears
So from I gathered from earlier posts, there are no issues with running lightened flywheel (ACT Streetlite) with 4.083 gears. Anyone running that setup? Comments, drawbacks, stories of great wins or terrible defeats?
Old Mar 25, 2011 | 05:41 PM
  #742
ihellaheart350z's Avatar
ihellaheart350z
No issues with lightweight flywheel. I'm running JWT clutch/flywheel combo with 4.08 gears and they work very well together.
Old May 1, 2011 | 12:13 AM
  #743
JDMStanced's Avatar
JDMStanced
what is the part number on these gear/final drive?
Old May 1, 2011 | 01:40 AM
  #744
kingpin.andy's Avatar
kingpin.andy
Don't have a part #, but it's out of a Nissan Frontier King Cab truck, so that should help you find it. Just google Nissan truck 4.08, or you can find it at pretty much any nissan mod vendor site. Should cost 450ish.
Old May 1, 2011 | 02:01 AM
  #745
JDMStanced's Avatar
JDMStanced
Can it be purchased from a Junkyard for cheaper?
Old May 1, 2011 | 04:33 AM
  #746
kingpin.andy
I'm sure it could. Don't see why not as it's a stock part for those trucks. Just make sure you're pulling it out of the correct model Frontier. I can't remember which one it's out of off the top of my head, but you can google it to find out for sure.
Old May 1, 2011 | 07:58 PM
  #747
JDMStanced's Avatar
JDMStanced
2005-2007 King Cab M/T 2.5 Final Drive model: C200
http://www.vibratesoftware.com/html_...rive_axles.htm
Old May 8, 2011 | 10:56 AM
  #748
ian99rt's Avatar
ian99rt
Definately cheaper out of a Junkyard, I snagged mine for $270 shipped. Great condition and came out of a 30k miles 2005 Frontier King Cab.
Finally setting the gears and quaife diff up this week.
Will have a fully detailed DIY written up once its all done and installed.
Old May 8, 2011 | 01:06 PM
  #749
JDMStanced's Avatar
JDMStanced
hit me up where you got it shipped from
Old May 8, 2011 | 01:53 PM
  #750
ian99rt's Avatar
ian99rt
Default 4.08 gears
I found mine by looking through car-part.com
It is a network of auto salvage yards where they can list the parts, condition, and price.
There was a place in Southern Washington that had a whole rear axle for about $300, but they would not take it apart to ship.
I got lucky found a place in AZ that had the rear axle messed up but they pulled the gears and diff out. Was sitting on their shelf for a year or so wrapped in plastic when i called.
Search around for yard listing other rear axle parts and call them. Thats how I found mine.
Old Jun 23, 2011 | 03:47 PM
  #751
nismomike's Avatar
nismomike
sorry to bring up an old thread, but just wanted to ask one simple question, and want one simple answer! I have an 08 Z, ecu tuned, top speed governor turned off. If the 4.083 gears are installed, could I--theoretically, utilize 6th gear to keep going past the 5th gear limit of 140ish something miles an hour that the 4.083 would bring? To go 160+? Just wondering!
Old Jun 24, 2011 | 01:14 PM
  #752
Pat Bateman's Avatar
Pat Bateman
I have the 4.08 gears with the factory tune and have hit 160, no more.
Old Jun 26, 2011 | 02:11 PM
  #753
zeyn83's Avatar
zeyn83
Default 3.91 vs 4.08
I also have a 08 HR with rev limit increased by 500rpm. I guess the top speed depends on the tire size as well. I have 275/35/19 tires in rear which is I believe close to 27" slick. I'm trying to decide between the 3.91 and 4.08 gears. I rarely go up to 160 but I do once in a while and I don't want to cut it down at all. Which one would you guys go with considering my setup?
I drive about 70 miles/day on highway and that is another reason why I was afraid 4.08 might be overkill.
I also have the Touring model so I assume I don't need an aftermarket LSD right?
Thank you guys for your help and time!
Old Jun 27, 2011 | 12:20 PM
  #754
doshoru's Avatar
doshoru
It'll be a difference of ~145 rpms or so at 80mph in 6th between the 3.91's and 4.08's. Not worth worrying over.
Old Jun 27, 2011 | 05:33 PM
  #755
jmccarty's Avatar
jmccarty
Look back on page 34 of this thread. You can theoretically hit 212mph with this final drive if you can rev to 8,600rpm with the tire size I'm using. There is a spreadsheet posted on page 34 of this thread that will answer for whatever combo you have.
Old Jul 1, 2011 | 12:31 PM
  #756
CTZ860's Avatar
CTZ860
Hey all, was wondering if I go 4.08 gears and I want to get all new bearings and gaskets should I be getting them for the frontier as well or the OEM ones for the Z diff?
Old Jul 6, 2011 | 01:26 PM
  #757
Steve-O Z33's Avatar
Steve-O Z33
The OEM stuff for the Z is what you'll need. You still have a 350Z differential, just a Frontier ring and pinion. Here is a parts list: http://mynismo.com/products/?id=5365
My diff. is in the shop now being built. Can't wait to get it back!
Old Jul 12, 2011 | 06:27 AM
  #758
etownz33's Avatar
etownz33
Very soon I will be swapping back to stock gearing if anyone is looking for a set of 4.08's. They were fun for a while but now that fi im sick of shifting every 2-3 sec. For N/a they are awesome and for the 1/4 they are good for et's if you can hook up, but for everyday cruising/ hiway not overly impressed
Old Jul 12, 2011 | 08:21 AM
  #759
1sick350z's Avatar
1sick350z
I will consider taking them from you when the time comes. Just let me know
Old Jul 12, 2011 | 09:17 PM
  #760
etownz33's Avatar
etownz33
Sounds good
