crank pulley?
Old Oct 7, 2007 | 04:39 PM
mililani00's Avatar
mililani00
Default crank pulley?
what are some good and bbad avantges of have a crank pulley?
Old Oct 7, 2007 | 05:26 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
bad: underdrives your ac. Requires non oem size belts. May cause harmonic issues. Not too compatible with a sc. May screw up key way or crank seal.
good: shifts powerband a little. rev faster.
Old Oct 7, 2007 | 08:30 PM
hbenet's Avatar
hbenet
Unorthodox Racing produces also a stock sized, thus you get the reduced weight benefits, without the disadvantages.
Old Oct 7, 2007 | 08:32 PM
Nexx's Avatar
Nexx
i highly suggest the UR standard sized pulley. you get 95% of the gains for the weight reduction so getting the under driven version just isn't worth it.
Old Oct 8, 2007 | 10:53 AM
mililani00's Avatar
mililani00
would it fck my a/c or anything?
Old Oct 8, 2007 | 01:37 PM
VTS's Avatar
VTS
I live in Tennessee and I have the UR underdrive crank pulley. My air works just fine in the summer heat here and so far I have yet to experience any problems.
Old Oct 8, 2007 | 04:00 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
that's assuming you've got an underdriven one
there is no way it can screw up the key way or crank seal unless its poorly made or put on with reckless abandon (ie BFH method)
As for the harmonic issues...let's not get started on this again
Old Oct 8, 2007 | 04:01 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
tell that to the people with the KJR pulley.
Old Oct 8, 2007 | 04:03 PM
lbz's Avatar
lbz
I put the underdrive UR set on this summer. No issues with the A/C or my custom audio which has 2 separate amps.
Old Oct 8, 2007 | 04:04 PM
Z1 Performance
Former Sponsor
hence why I posted what I posted
if its a properly made and engineered piece, installed by someone familiar with installing such a part (it's very easy), you will now have any problems
I had the UR underdriven pulley on my car since it came out in 2003 - never any issues with the heat, or with my stereo (I have a system). Put around 45k miles on my original motor before yanking it out for the built one I have now...which also uses a UR underdrive crank pulley
Old Oct 8, 2007 | 04:18 PM
VQ40's Avatar
VQ40
Got one on my Frontier. No issues. It's underdriven by 12%. Definitley a worthwhile mod that you can feel.
Old Oct 8, 2007 | 07:47 PM
citymunky's Avatar
citymunky
Thumbs up No Problems here
I have the UR underdrive pulley set, and i have yet to have problems with the A/C or my audio system.
Old Oct 8, 2007 | 09:49 PM
RBlover69's Avatar
RBlover69
which of your 4-5 options on your site would be a good selection for a revup motor that wants to be road raced??
Old Oct 9, 2007 | 04:33 AM
Z1 Performance
Former Sponsor
the only pulley we sell for a Z is Unorthodox
The difference between underdriven and non underdriven is negliable - it's all user preference. Same goes for the difference between the full pulley set and the crank pulley alone. All user preference at that point.
The primary gains come from weight reduction on the crank pulley
Old Oct 9, 2007 | 09:34 AM
ACEMAN's Avatar
ACEMAN
Master
Thumbs up
I have had the Unorthodox crank pulley for around 4 years..
No problems at all..
Todd
Old Oct 9, 2007 | 11:58 AM
Frostydc4's Avatar
Frostydc4
Are the gains with the standard size UR pulley noticable?
Old Oct 11, 2007 | 06:04 AM
Z1 Performance
Former Sponsor
yes
Old Oct 18, 2007 | 12:24 PM
Fooshe's Avatar
Fooshe
What should a UR underdrive pully set cost?
Old Oct 18, 2007 | 12:51 PM
RebelinRI's Avatar
RebelinRI
^ Try their website. Always a good place to start. Then look at some vendors here, even better prices!
Old Oct 18, 2007 | 02:00 PM
Quamen's Avatar
Quamen
Unorthodox is the way to go!
Their quality is top notch (not saying others aren't), they offer a number of options crank pullies which can be definable by function or cost in the end such as what series pulley you go with.
While I would suggest that you go through a supplier like Z1, dealing with Unorthodox personally is also a good route if you can. Shawn B gives top notch customer service an UR.
I would personally go with the stock diameter light weight version for crank pullies and do accessories if you want them for looks. The main gains, as stated by others, will be in the weight savings and the underdrving is negligible.
