Rattle / Buzzing at 2500 and 3300 RPM's
Old Oct 13, 2007 | 06:12 AM
RSX004's Avatar
RSX004
Default Rattle / Buzzing at 2500 and 3300 RPM's
Done quite a bit of searching on this subject buy couldnt find any occurances without test pipes. The Z is making a really annoying rattle/buzz/raspy noise when I hit 2500 and 3300 rpms. The noise will only last for about 100 rpm's and only when the car is in second gear or higher - the noise will not occur in neutral or in first gear. I do have a Nismo exhaust which has scraped a few times due to the car being lowered. Nissan of course says that the noise is comming from my "aftermarket suspension" - obviously this is not the case. Any ideas?
Old Oct 13, 2007 | 06:23 AM
mikead_99's Avatar
mikead_99
The flex sections on the Nismo will do that under pressure with tp's, mine did it with hfc's.
Old Oct 13, 2007 | 06:45 AM
TheProfessional's Avatar
TheProfessional
I can say that my 06 dash rattles at certain speeds because my BFG tires are so loud.
Old Oct 13, 2007 | 07:10 AM
RSX004's Avatar
RSX004
Thanks for the replies and sorry for the confusion - I have the stock cats, thats why its just not making any sense to me.
Old Oct 13, 2007 | 09:20 AM
bbs350z's Avatar
bbs350z
i was gonna say itd be your test pipes, but seeing as you dont have those... theres a ground cable that goes to the rear muffler. when i had my stock one on, it made a weird noise when i revved it. but i took it off and no more noise. the only rasp i got was from tp's.
Old Oct 13, 2007 | 01:44 PM
RSX004's Avatar
RSX004
I can also detect a smell exiting the driver's side - almost smells similar to a new exhaust system.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
etkms
Jun 19, 2022 06:30 PM
Justin100
Nov 29, 2015 03:58 PM
azndoc
Wheels Tires
Oct 10, 2015 02:59 PM
PureR3d
Sep 10, 2015 06:23 PM
