any difference btw 2003 and later model's clutch?
Old Oct 22, 2007 | 05:31 AM
silviakoko's Avatar
silviakoko
Default any difference btw 2003 and later model's clutch?
any difference btw 2003 and later model's clutch? can i use later model clutch and flywheel on my 2003 track?
Old Oct 22, 2007 | 06:28 AM
medstudent25's Avatar
medstudent25
to the best of my knowlege any 03-06 flywheel and clutch would work, but if you are changing it out why not put something that is lighter and has more clamping force. i prefer JWT personally
Old Oct 22, 2007 | 11:10 PM
silviakoko's Avatar
silviakoko
but the clutch feel of 2006 is lighter than my 2003 and the gear seem to be shorter and eaasier to engage, besides i do not want noise or what ever issue people are having with their aftermarket flywheel
Old Oct 23, 2007 | 05:47 AM
medstudent25
in my opinion the chatter that everyone refers to is blown way out of proportion. i have a jwt combo, and there is very little chatter at all. not to mention the added performance from it. do you have exhaust? i am running stock and still can barely hear it. as far as the flywheel that the clutch attaches to, they are the same through out all non-revup engines, but i am not sure if it changes on the 06's revup. the reason why the gears engage easier is because they switched back to brass synchros on the newer revised transmissions
Old Oct 23, 2007 | 03:19 PM
silviakoko's Avatar
silviakoko
cheers
