//////fuel pump relay wires//////
Old Nov 4, 2007 | 02:58 PM
ALO8's Avatar
ALO8
Default //////fuel pump relay wires//////
anyone know which wire is the (+). i think i saw like four wires coming out of the pump. Also which way do they split, the black wire tube splits towards the center and towards the passangers side panel?
Attached Thumbnails //////fuel pump relay wires//////-img_7727.jpg   //////fuel pump relay wires//////-img_7729.jpg
Old Nov 6, 2007 | 08:24 AM
BabyZiLLa's Avatar
BabyZiLLa
Hey dude.. I got your PM. Sorry i never did work it out.. I'd still like to know whats what myself.
Old Nov 6, 2007 | 10:06 PM
ALO8's Avatar
ALO8
anyone??
Old Nov 6, 2007 | 10:18 PM
punish_her's Avatar
punish_her
In the service manual in the Power Ground section on PG-14; power comming into the coil of the relay is black and red. The power leaving the relay is lavender and white.
In the future it may be benificial to you, when asking wiring questions, to include the color of the wires not just the "blake wire" tube. Since the power flows straight through there realy isnt a pos and neg per say. But it would be benificial to wire the relays in parallel and not in series. There is less of a current drop on the system.
Lastly, you may want to clarify your query a little. Are you trying to find the OEM fuel pump realy wires or are you trying to find wires so you can wire a secondary relay for an external fule pump?
Old Nov 7, 2007 | 08:22 AM
ALO8's Avatar
ALO8
i didnt really get to see the colors of the wires, the only one i see is the black with yellow one, ill look at it later. im trying to find the wire that gives the oem fuel pump its power. ill look at the other colors there are when i get a chance.
Old Nov 11, 2007 | 01:22 PM
ALO8's Avatar
ALO8
okay so there are 5 wires:
black/red
black/yellow
black
yellow
purple/white
So if i want to cut off the power before it reaches the relay, which wire do i cut?
Old Nov 13, 2007 | 09:57 PM
ALO8's Avatar
ALO8
so I take it the black and red supplies the fuel pump with power right? the lavender and white is the power leaving the relay to where does it go?
Old Nov 16, 2007 | 02:20 PM
ALO8's Avatar
ALO8
anyone know which wire is the (+) for sure?
Old Nov 16, 2007 | 09:21 PM
ALO8's Avatar
ALO8
what year manual are u looking at?
Dr.Paulyy
Jul 29, 2019 07:45 AM
TrackFiddy
Sep 24, 2015 11:40 PM
MyZ2Slow
Mid-Atlantic Marketplace
Sep 9, 2015 10:17 PM
