Larger Oil Filter for the Z
Old Nov 22, 2007 | 01:38 PM
Mike Wazowski's Avatar
Mike Wazowski
Originally Posted by JonsilvZ
When I changed the oil in the Z about a month ago the Nissan filter is now made in China. It was made in Japan. So I went with the Mobil 1 filter.
I bet people are going to start seeing high lead amounts in their UOA now.
Old Nov 22, 2007 | 02:59 PM
warmmilk's Avatar
warmmilk
Originally Posted by mw9
Are the 07's the same?
yes
Old Nov 22, 2007 | 03:57 PM
Monsta's Avatar
Monsta
Would the size of the filter allow for more filtering capacity? More area for pollutants before the bypass opens.
Old Nov 22, 2007 | 05:46 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
half of your car is made in China...half of just about everything in the world is made in China, just like 20 years ago, it was in Japan, and 50 years ago, it was the US.
Old Nov 22, 2007 | 06:57 PM
FAIRLADYZ_MANnE's Avatar
FAIRLADYZ_MANnE
made at .2 cents sold for 10$ here
whats united states has done
Old Nov 22, 2007 | 09:30 PM
350ZTheStandard's Avatar
350ZTheStandard
Damn China, another item I have to keep a close eye on now.
Hey, maybe lead is a good additive for oil.
Old Nov 23, 2007 | 06:48 AM
mw9's Avatar
mw9
I don't worry where its made, I have been using Amsoil products for years now. An american product.
Old Nov 23, 2007 | 08:38 AM
lowrider's Avatar
lowrider
Originally Posted by gothchick
Specs are pretty close. Do you think this is okay?
HP-1008
Height: 2.91 in (74 mm)
Outside Diameter: 2.656 in (67 mm)
Thread Inside Diameter: M20 x 1.5
PSI Relief Valve: 11-17
Anti Drain Back Valve: Yes
Style: Canister
Weight: 0.5 lb (0.2 kg)
HP-1010
Height: 3.75 in (95 mm)
PSI Relief Valve: 13-17
Style: Canister
Based on the recommendations of a K&N tech back in '03, I've been using an HP1006. Not for any Nissan product, but seems to work fine.
Outside Diameter: 2.781 in (71 mm)
Style: Canister
Lou
Old Nov 26, 2007 | 07:12 PM
gothchick's Avatar
gothchick
Style: Canister
Lou
Thanks Lou~
That looks perfect! I'll try that one on the next oil change~ :-)
Old Feb 24, 2008 | 06:44 PM
Mike Wazowski
bump for good information
Old Feb 24, 2008 | 08:34 PM
seZy350's Avatar
seZy350
oil filter is an oil filter...
Old Feb 24, 2008 | 08:59 PM
Eazzy's Avatar
Eazzy
The smaller is fine...if it makes you feel better--use the larger.
To be honest IMO filters were introduced as a money making venture---you're pick up tube has a screen that will eliminate anything that may hurt the pump.
There are so many things we take for granted are "Law" because we were told it was.
The pickup tube screens debris that will wreak the gears in the pump.
The main thing is ---change your oil at sensible intervals
Old Feb 26, 2008 | 12:09 PM
bommart's Avatar
bommart
i have the pathfinder filter on mine. my mechanic put it on there for extra filtration....
Old Mar 12, 2010 | 12:04 PM
Steve-O Z33's Avatar
Steve-O Z33
I bought a WIX filter at O'Reilly's a few weeks ago and the guy said it's the same part # for a Briggs & Stratton lawnmower engine. I asked if he was joking and he said that he was serious.
I am going to swap my filter out for the larger 1 next time.
Old Mar 12, 2010 | 02:00 PM
tquill's Avatar
tquill
I'm getting the HP 1010 next time around. It's the same as the M1-110.
Old Mar 13, 2010 | 06:25 AM
exZilaration's Avatar
exZilaration
This thread is still going?
Old Mar 13, 2010 | 06:46 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
yea started before u were even a member here.
Old Mar 13, 2010 | 12:32 PM
  #38
MDK's Avatar
MDK
What part number is this?
Old Mar 22, 2010 | 12:26 PM
  #39
ipodhustle's Avatar
ipodhustle
Old Mar 22, 2010 | 10:54 PM
  #40
winchman's Avatar
winchman
"To be honest IMO filters were introduced as a money making venture---you're pick up tube has a screen that will eliminate anything that may hurt the pump."
There are lots of aircraft piston engines that came from the factory with just screens, and the oil had to be changed every 25 hours. Adding a filter kit allowed the oil change interval to be doubled to 50 hours.
Yeah, the screen will protect the pump from damage, but it doesn't do much to protect the bearings and cam.
I know aircraft piston engines are much simpler than Z engines, but their owners are VERY interested keeping them running well.
