Tune or not tune lightly modified VQ35DE
Old Dec 1, 2007 | 04:46 PM
wolffttu's Avatar
wolffttu
Default Tune or not tune lightly modified VQ35DE
looking for arguments in weather or not one should tune the ECU, piggy back or use a SAFMS. should i or should i not do one of the above if i have headers, test pipes with cats, headers,pop charger,exhaust and plenum spacer, short shifter, 3.9 gears. your input will be appriciated. looking for arguments for or against tuning the engine or should i just wait to do anything and just save for F/I and then do stand alone ?
Old Dec 1, 2007 | 04:50 PM
ofl0926's Avatar
ofl0926
just go get a utec... tune it with the mods you have. it will be a big difference in power... and then you will have it there if you go boost.
remember that your not getting all your power from your mods right now and a tune will make a huge difference
Old Dec 1, 2007 | 04:59 PM
wolffttu's Avatar
wolffttu
questions concerning the mass airflow sensor and the stock ecu how much extra air flow can you put into the engine beofore the o2 sensors and maf meter start confusing the computer to where the ecu wont open the fuel injectors enough. to match the amount of fuel to air. will the ecu keep from letting the injectors going more than the safe limit of the duty cycle for the injectors?
Old Dec 1, 2007 | 05:11 PM
VIZAGE's Avatar
VIZAGE
Defiantly have tuned with all those NA mods. Let us know the before and after results?
Old Dec 1, 2007 | 08:10 PM
eltness350's Avatar
eltness350
The Untouchable
tune = better response...and prob gain a few hp throughout the rpm band...that is good...
Old Dec 1, 2007 | 08:40 PM
wolffttu's Avatar
wolffttu
will do. the only thing is i'm not going to play with a module i dont know how to use. i need to find a good vq tuner. any in mind?
Old Dec 2, 2007 | 06:43 AM
wolffttu's Avatar
wolffttu
do any of you all know of a good tuning shop? location is not a concern
Old Dec 2, 2007 | 12:46 PM
superchargedg's Avatar
superchargedg
Damn Noobs
sgp is in texas.
Uriyo_
Sep 8, 2021 08:46 AM
2ndchanceZ
Oct 26, 2015 08:03 PM
350z82
Oct 1, 2015 06:25 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
