Need help!!!
Old Dec 7, 2007 | 11:46 AM
JoshuaJJackson's Avatar
JoshuaJJackson
Default Need help!!!
Ive been training for a month and i get home last night and go to drive my car. takes three trys to start. and its was revivng high was cold and havnt been run in awhile. After it cooled down to about 900 rpms it wont rev higher then 1.5k rpms. even with the pedal all the way to the floor? ideas? suggestions?
Old Dec 7, 2007 | 02:10 PM
JoshuaJJackson
bump
Old Dec 7, 2007 | 02:26 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
simple thing to try first is a battery reset - then post from there
Old Dec 7, 2007 | 02:54 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
the car is in limp mode -- this occurs due to several different reasons
if you get a check engine light, you need to go get that code scanned.
Old Dec 7, 2007 | 02:59 PM
JoshuaJJackson
That's the first thing I tried. The hobby shop here told me to try fuel injector cleaner added some ran for an hour. Still nothing.
Old Dec 7, 2007 | 03:03 PM
T_K's Avatar
T_K
Sounds like a dead MAF sensor. I don't know about the Z, but when I had my 2000 Maxima, typical symptom of a dead MAF is limp mode.
TK
Old Dec 7, 2007 | 03:25 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
so... no check engine light?
dead MAF would give a check engine light. ... HELL if just about ANY sensor on this car dies, you get a check engine light.
Old Dec 7, 2007 | 03:38 PM
JoshuaJJackson
I got a check engine light had one for awhile due to test pipes my buddy got a scanner ill have him scan it in a bit and post it up
Old Dec 7, 2007 | 03:45 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
most likely the limp mode triggered another code.
Old Dec 7, 2007 | 04:41 PM
JoshuaJJackson
Alright this is what i got its throwing 2 codes.
P1122 - Electronic Throttle Control Actuator
and then the second code is the same thing except its
PD P1122 - Electronic Throttle Control Actuator
Old Dec 8, 2007 | 12:37 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
hmm someone with a service manual could help you out.
or just limp it to the dealer. don't erase that code, should be under warranty.
