Will Changing Transmission Fluid Void Warranty?
Old Dec 15, 2007 | 12:55 PM
chizarium's Avatar
chizarium
Default Will Changing Transmission Fluid Void Warranty?
I was just wondering if anyone knew the answer to this:
If I changed the transmission fluid in my 04 350Z (manual transmission) would it void the 5-year/60,000 powertrain warranty?
I just bought this 04 Touring with 13k miles on it and the transmission is the worst I've ever driven. Very notchy. I also get a 2nd gear grind half the times I shift at low speeds.
However, the problem is not bad enough yet where the dealer would actually consider something wrong and replace the transmission under warranty.
I've read a few threads where people changed their stock MTF with a Redline MTL / MT-90 mix and experienced positive results.
If I change the fluid to the Redline stuff will that void my warranty?
I have a feeling I'll be bringing the car to the dealer anyway sometime in the future for a new trans but I'd like to ease the pain for now by trying whatever I can to smoothen out the shifting.
Any help is greatly appreciated, thanks.
Old Dec 15, 2007 | 01:23 PM
SpeedRcr's Avatar
SpeedRcr
i guess the search button is broken again
Old Dec 15, 2007 | 01:24 PM
Russ@Z1's Avatar
Russ@Z1
No, it won't. You'll be fine.
Well, that's as long as you don't put something in that doesn't belong.
Old Dec 15, 2007 | 02:31 PM
BTW how often do you change the windshield wiper fluid?
Old Dec 15, 2007 | 03:20 PM
Russ@Z1's Avatar
Russ@Z1
Never! Now that would void a warranty!
Oh, and don't forget to make sure your blinker fluid doesn't leak out either!
Old Dec 15, 2007 | 03:39 PM
350ZTheStandard's Avatar
350ZTheStandard
Blinker fluid doesn't have to be changed out, just need to rotate the blinker fluid and use 50 weight Nismo fluid.
Old Dec 15, 2007 | 03:41 PM
SniperHunter's Avatar
SniperHunter
ware kan i by sum blinking flooid guyz?
thx
Old Dec 15, 2007 | 03:53 PM
SpeedRcr's Avatar
SpeedRcr
thx
at the same store that has a dictionary
Old Dec 15, 2007 | 04:04 PM
JonsilvZ's Avatar
JonsilvZ
Changing tranny fluid is better for the tranny.
Old Dec 15, 2007 | 04:37 PM
invazn's Avatar
invazn
wait, where is my vtec fluid tank at?
Old Dec 15, 2007 | 04:46 PM
chizarium's Avatar
chizarium
can the dealer tell if the fluid was changed?
Old Dec 15, 2007 | 05:05 PM
Russ@Z1's Avatar
Russ@Z1
Yes. They have a sensor mounted to the inside of the housing. All they have to do is plug into the computer and check the readings.
If you reset your ecu three times, it will clear the readings. Then they'll have to go by what you tell them.
Old Dec 15, 2007 | 05:11 PM
Eazzy's Avatar
Eazzy
No --It wont void your warranty
Old Dec 15, 2007 | 05:14 PM
Delako's Avatar
Delako
transmission is still covered, but it voids your warranty on the fluid and fluid only
Old Dec 15, 2007 | 09:31 PM
I thought that was only on the NISMO 350Z.
Old Dec 16, 2007 | 04:29 AM
Z04's Avatar
Z04
yeah, it is in the sticky up top as well.
Old Dec 16, 2007 | 05:08 AM
bailey bill's Avatar
bailey bill
thx
Right here:
http://kalecoauto.com/index.php?main...1add1913356478
bill
Old Dec 16, 2007 | 07:58 AM
nismo240r's Avatar
nismo240r
If you use anything other than what Infiniti/Nissan specifies (Genuine Nissan Fluid) then yes it will where I'm at. . .
Old Dec 16, 2007 | 08:01 AM
chizarium's Avatar
chizarium
what sticky?
i dont see this exact question ever asked
Old Dec 16, 2007 | 08:18 AM
JonsilvZ's Avatar
JonsilvZ
Just go with the OEM tranny fluid. You only have to replace it every 30k miles.
