Clutch question
Old Dec 19, 2007 | 06:13 AM
supra crazy's Avatar
supra crazy
Default Clutch question
What determines how much clutch holds? I thought it was the pressure plte since i is what applies the pressure to the disc...... My question is does the disk it self have much to do with how much power it holds?
Old Dec 19, 2007 | 08:40 AM
supra crazy
bump!
Old Dec 19, 2007 | 05:59 PM
Corradoslc7's Avatar
Corradoslc7
The friction material that the clutch disc is made of is a key aspect that determines how much power the clutch can handle. This is why when the clutch disc wears out it really doesn't matter if the pressure plate is still applying alot of pressure, the clutch disc will still slip.
Old Dec 20, 2007 | 12:12 PM
Spddracer's Avatar
Spddracer
There are many variables to how much TQ a clutch can hold.
Disk Material, Pressure plate clamp load, Flywheel surface material ect.
Here is a TQ calculator that can give you a basic idea of how much a certain disk material and pressure plate clamp load can hold. http://www.zoomclutch.com/torque_calculator.html
FYI, A 350Z clutch facing on the disk measures about 9.85"x6.125"
Most of the common materials are listed there except the "Feramic" material that it used in the DxD clutch kits I offer.
Feramic has a .67 Coeff of friction.
sherm
Apr 11, 2020 05:21 PM
issyz
Jul 2, 2017 03:04 PM
