South Bend clutches
Old Dec 21, 2007 | 01:22 PM
SpoilsofWar's Avatar
SpoilsofWar
Default South Bend clutches
Just wondering if anyone here is running one of South Bend's clutches? I have heard pretty good stuff about them as far as being able to handle lots of torque while still retaining drivability.
Also, if any of you are using a SB clutch, what flywheel did you mate it with?
Thanks
Old Nov 18, 2012 | 09:29 AM
joshua350z6841's Avatar
joshua350z6841
anyone have any input on this would like to know myself
Old Nov 18, 2012 | 01:04 PM
jerryd87's Avatar
jerryd87
i run the highest rated full face they make, its not bad on the street but i have the rjm bracket. mine started to slip at 601 ft lbs of torque at the wheels and since they have down rated the clutch a little and between them and concept z they had a custom 6 puck sent to me for free but havnt had a chance to install it yet.
mated to fidenza/jwt flywheel
Old Nov 18, 2012 | 03:56 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
You don't have the highest rated southbend. There is a extreme series above yours, custom order though
Did you ever complete the break in on it? I know last time it had very low miles in it and is most likely the reason it was slipping at 600ish. That clutch (stage 5) will hold well over that power after complete break in.
There are options that we can do for people and custom build a clutch for them , something we've done for a long time with South Bend.
Old Nov 18, 2012 | 04:08 PM
jerryd87's Avatar
jerryd87
is that a full face though, was my understanding they dint have anything better for full face? i broke it in more(4k miles on it now) while keeping it out of boost and got a little better but not much mayby 10 ft lbs of torque tops, i have to keep the boost under 20 psi still. i have the new 6 puck that is custom built and i can see it holding alot more it seems to be a different material(based on color) and only mayby 1/3rd the contact area.
for the price though i really cant complain they really came through with customer service, and the price is a fraction of what something like a carbonetics triple or rps twin would cost new. also have to figure southbend rates it at 690 at the engine, when i dynoed before that is ~720 at the engine i was making when it was slipping it might be around 730-740 now after some more break in but when i take it out its getting alot of power applied repeatedly and it has been said the clutch ratings are at 70 degrees, it stays 85 in hawaii plus it gets hot enough that i see my exhuast glowing through the holes cut in my hood.........through heat wrap so i cant really complain hoping the 6 puck will help keep it cooler and provide a large boost in holding power. supposedly what i have now is guaranteed to hold at least 825 ft lbs of torque.
Old Nov 21, 2012 | 10:43 PM
Nealoc187's Avatar
Nealoc187
my buddy's running SBCs highest rated full face feramic clutch as well on his Z. it held well at around 540tq on mickey DRs for the one full pass he made on it (broke an axle on the next pass so we didn't really get a chance to test it much lol).
sherm
Apr 11, 2020 05:21 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
