Pivot Ball
Old Feb 10, 2008 | 05:39 AM
multiscape's Avatar
multiscape
Default Pivot Ball
when changing clutch fork pivot ball with aftermarket pivot ball the aftermarket ball is longer thus causing t.o.bearing to move further foreward on shaft and closer to pressure plate when installing trans in vehicle seems no to want to bolt together like stock ball set up can someone please advise.
Old Feb 10, 2008 | 05:53 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
never heard of an aftermarket pivot ball, but if thats the case, then it sounds like you'll need a different length throw out bearing. As to what you will need, I have no idea...I never saw any point in changing the pivot ball for anything else
Old Feb 10, 2008 | 06:15 AM
multiscape's Avatar
multiscape
i ordered jwt clutch & flywheel kit off import parts pro and on their site they reccomend to change clutch line pilot bushing & pivot ball but when we got the pivot ball it does not have the same dimensions as stock it is 3/4" longer, they say the stock pivot ball is weak
Old Feb 10, 2008 | 06:20 AM
Z1 Performance
Former Sponsor
stock pivot ball is weak? news to me....I've never once heard of anyone breaking theirs
sounds to me like you need to call whomever sold you this item
Old Feb 10, 2008 | 06:25 AM
Eazzy's Avatar
Eazzy
Somethings fishy here, .75 is a substantual difference, there is nothing wrong with the OEM ball. Id be curious to see the reasoning behind this and would appreciate the response from the supplier
BTW--- as a rule, if there is any weaknesses, its the arm, not the ball. Thats what does the work
Old Feb 10, 2008 | 06:31 AM
multiscape's Avatar
multiscape
good thing we installed a lift in our shop for this project we had the tranny in and out twice yesterday i would not want to do this on the jack stands hope somebody can tell me if they ever tried the longer pivot ball or what i thought was if you did use the longer ball you would need a different clutch fork
Old Feb 10, 2008 | 11:35 AM
ImportPartsPro's Avatar
ImportPartsPro
Vendor - Former Vendor
Multiscape,
I sent you a PM about this. Looks like Nissan has changed the pivot ball in a few different years and models. You will not be able to use the pivot ball I sent you in your car unfortunately. I will refund you for the pivot ball plus any return shipping.
I will be finding out exactly which models are different and will be making a shorter one to fit those models shortly. I apologize for this mistake but leave it to Nissan to make changes between years and models even when they don't need to
As far as needing a pivot ball, they have been a major issue in the 300zx and 240sx communities for years. So much that both Nismo(Click me) and JUN(Click Me) make aftermarket ones just like I do. Here is an example of one that has already broken on a 350z:
https://my350z.com/forum/engine-and-drivetrain/306853-clutch-stuck-to-the-ground-and-wont-come-back-up-help.html
The problem with the stock pivot ball is the increased pressure to push in the clutch puts more pressure on the pivot point(pivot ball) so sometimes it will snap off because it is made from weak metal. The ones I produce are made from Chromoly so they hold up to the increased pressure better.
Old Feb 10, 2008 | 06:25 PM
captj3's Avatar
captj3
Here you go. Mine was broken and missing when I changed my clutch after TT install. I was there when they took the tranny out. I just did my clutch again ordered a new ball and they sent me one that was to short.
Old Feb 10, 2008 | 09:22 PM
KRRZ350's Avatar
KRRZ350
Those were my exact words when someone dropped off a z32TT for a clutch job, I later found that his was already broken, I would have been screwed on that job if someone hadn't said "these are weak, you should get one".
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Row2K
North East Marketplace
Dec 27, 2015 12:09 PM
TrackFiddy
Sep 24, 2015 09:36 AM
Ace2347
Sep 22, 2015 03:12 AM
CrowzRSA
Sep 21, 2015 04:00 PM
