Question about radiator differences
Old 10-10-2017, 09:11 PM
irbullet
irbullet's Avatar
Default Question about radiator differences
well, my radiator on my AT Z went ouch, need a new one.
im in search of one, but the ones I am looking at says MT on it or doesn’t specify. Is there a clear difference between AT and MT radiators?
I found mixed answers online. I don’t want to waste any money.
thank you.
Edit: *i figured it out, already bought one online*
Old 10-14-2017, 10:30 AM
CK_32
CK_32's Avatar
You need a AT one. Most generic and OEM radiators are MT/AT.
The only difference is the AT able ones have both coolant hose hook ups, and nipples closer to the middle on the bottom for trans coolant lines for your tranny. MT's don't need that. AT's do.
So if you get a radiatior with the center nipples it will work. Other than that there is no difference.
Old 10-14-2017, 01:17 PM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
What CK said. An options if you dont get a radiator with the AT cooler you can always add a small oil cooler / trans cooler to accomplish the transmission cooling duties.
