Valve Covers...symptoms
Old Feb 21, 2008 | 10:47 PM
SuperBlack350z's Avatar
SuperBlack350z
Default Valve Covers...symptoms
i was going to check some maintainence mods on my other Z. I was wondering a few questions maybe some Z gurus would know. I know somewhat but wanted to make sure so i know exactly what i need to buy and do. Thanks.
1. If there is oil on the spark plugs, that would indicate bad valve covers itself which has to be replaced since the gasket is built in the valve cover for the spark plug holes?
2. If oil is leaking around the outside of the valve covers, that would mean the valve cover gasket has to be replaced?
3. what are the problems if valve cover gaskets are not replaced right away? What are the long term affects?
Old Feb 21, 2008 | 10:52 PM
blasian's Avatar
blasian
Seems to be a common problem. The entire valve cover gasket has to be replaced
Old Feb 21, 2008 | 11:03 PM
SuperBlack350z
you mean valve cover.
yes, i got quoted 250 dollars each at the dealers.
Old Feb 21, 2008 | 11:05 PM
blasian's Avatar
blasian
Naw, you can buy the valve cover gasket itself... the spark plug gasket part (can't remember what its called) is built-in the valve cover gasket.
There were some on mynismo.com but I can't find them anymore
Old Feb 21, 2008 | 11:10 PM
blasian's Avatar
blasian
Ahh, the tube seals!
Old Feb 22, 2008 | 07:38 AM
SuperBlack350z
bump
Old Feb 22, 2008 | 07:41 AM
taurran's Avatar
taurran
The only long term effect I can imagine would be increased oil consumption and the possiblity of it getting worse.
Old Feb 22, 2008 | 07:44 AM
HondaKiller's Avatar
HondaKiller
i had to replace the valve gasket cover in my old Camry. Not a big deal, long term affects would be burning oil and dripping it on your driveway. I would imagine if too much oil gets in a plug it woudl prevent it from firing.
Old Feb 22, 2008 | 07:46 AM
blasian's Avatar
blasian
Can someone confirm that the tube seals are built into the valve cover gasket and not the valve cover?
I may just order some for the hell of it but I'm not sure about taking on a task of replacing them myself
Old Feb 22, 2008 | 08:02 AM
SuperBlack350z
i'm pretty sure that it's built in the valve covers.
also, it's not a hard task to install. Take off top plenum, take off bottom plenum, drain some coolant, then you will have access to the valve covers.
Old Feb 22, 2008 | 08:10 AM
blasian's Avatar
blasian
Well... definitely not as bad as I thought. I can do that
I will ask my buddy who works at Nissan. That REALLY sucks if that's the case
Old Feb 22, 2008 | 02:44 PM
SuperBlack350z
bump
Old Feb 22, 2008 | 02:56 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Yes, the spark plug seals are built into the cover itself. I'm selling some very nicely painted reds ones for $150 if your interested.
Old Feb 22, 2008 | 03:43 PM
Eddie@Performance's Avatar
Eddie@Performance
Performance Nissan
If there is oil on the spark plugs that indicates a bad spark plug seal kit. This requires you to buy new valve covers, as dumb as it sounds, you cannot buy this separately.
Yes, if its on the outside then you can buy the gasket separately, passenger part# 13270-8J102 for the drivers side 13264-AM610.
Leaks become progressively worse as time passes, if the leak inside the spark plug tube becomes bad enough to flood, it will cause a short in the coilpack.
Old Feb 22, 2008 | 07:54 PM
undrgnd's Avatar
undrgnd
Sort of on the same subject, how does a spark plug seal go bad so quickly? Considering the cost and difficulty in replacing one, has anyone contacted Nissan about a TSB?
Old Feb 23, 2008 | 12:18 AM
SuperBlack350z
Yeah, i've pmed you about it. I remember you weren't sure the mileage on them. I just dont' want it to happen again so not sure how high the risk are buying used ones. is there a way to tell they have bad seals?
Old Feb 23, 2008 | 12:20 AM
SuperBlack350z
thanks for clearing that up for me. Just wanted to make sure. I got the gaskets already. Is there a way you can PM me the best price for brand new valve covers shipped? Thanks for your informative post.
Old Feb 23, 2008 | 05:04 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Looking is really the only way you might be able to see something. I can send you some pics of the underside if you want.
Old Feb 25, 2008 | 01:27 PM
blasian's Avatar
blasian
Looks like I'll be ordering a valve cover myself
Old Feb 26, 2008 | 04:32 PM
silvaZ32's Avatar
silvaZ32
i have oil in my spark plugs and i went to nissan they said it was the gasket, but josh at Z1 motorsports told me it was the whole valve cover. i will just but new valve covers and do it myself
