Gasoline Brands
Old Feb 28, 2008 | 04:32 AM
go-fast's Avatar
go-fast
Originally Posted by undrgnd
Conspiracy brother,
You are entitled to you opinion, as uneducated as it may be. I would rather people find their own answers than listen to someone who couldn't compose a single, grammatically correct sentence, if their life depended on it.
you dismiss my post as inacurate,i counter with the research you recommend,you don't like the outcome and your only response is grammar?c'mon man you can do better than that!i didn't start this pissing contest but if thats the best you can do,i guess i finished it. p.s. i suppose detroitnews is a conspiracy rag?
Old Feb 28, 2008 | 05:28 AM
Originally Posted by Rekinyze
Have you ever noticed that you get varying performance from different brands of gasoline?
No.
Old Feb 28, 2008 | 05:53 AM
athenG's Avatar
athenG
I could care less about what detergent they use, I have performance car that needed gasoline that can help me get the full potential without putting it in danger. Most NA won't see the difference since most dont do any logging on their cars. Utec does detect knock (Maybe not the most sophisticated way) and my logs says Mobile/Exon suck!!! I want the highest Octane gas and less water mix in my gas coz that will lead to detonation. To bad Sunoco removed their 94 octane in NE (At least NJ and NY) This is the main reason I got a Water/Meth Kit, it is much cheaper than running race gas all the time.
Old Feb 28, 2008 | 06:05 AM
Ep3's Avatar
Ep3
i use bp, the biggest reason for this it is the only station arround me that still has separate hoses/nozzels for all 3 octane ratings. i figure if the person before me used anything other than 93, when i press the 93 there is still a bunch of 87 or 89 octane still in the hose. in NJ there is usually 1 hose for 87-91 and a seperate for 93. what do you guys think b/c i reall dont know how it works haha
Old Feb 28, 2008 | 06:19 AM
JZurita's Avatar
JZurita
edit: nvm
Old Feb 28, 2008 | 06:58 AM
athenG's Avatar
athenG
Hmmm never really payed attention to that. Most newer station use one pump now so I'm pretty sure or hope they did something about it. Either way, I usually put gas 10Gal or more so if someone did use a regular gas before me then that is going to be a small amount. There is a formula to find out how much octane you get if you mix two different octane gas.
Let say I used 1 gal of 87 octane gas and 12 gal of 93 octane gas.
1 and 12 is a total of 13. 1/12=8.3% 83 octane gas and the rest (91.7% 93octane). So, here is how you calculate it: [(8.3x87)+(91.7x93)]x100=92.502 or about 92.6 octane. Using this calculation, you only went down by .4 octane and this is if you actually put 1 Gal of 87 and mix it with 12 gal of 93. The number should be lower since you still have some 93 octane gas in your tank.
Old Feb 29, 2008 | 07:28 AM
bman350z's Avatar
bman350z
Have noticed Shell varies, sometimes good, sometimes sluggish. My opinion is it's either water or ethanol. I was curious, so I checked the manual, said 91 Octane and no more than 5% ethanol. Hess down here says no more than 10% ethanol, right on the pump. Anyone know what gas stations don't use ethanol? Or do they all put ethanol in their gas?
Old Feb 29, 2008 | 07:37 AM
jonnylaw's Avatar
jonnylaw
In Chicago--It's up to 10% ethanol as well. I've heard in colder weather climates in the winter, they put more ethanol in the gas to reduce emissions, but this hurts performance.
Old Mar 3, 2008 | 04:12 PM
bman350z's Avatar
bman350z
Default update
Did some research and at least in S FL, they are starting E10, but only a few stations carry it. Hess for one and they had this big sign on the pump "Not more than 10% Ethanol". Tried Texaco this go around and works well. Guess it's hit and miss.
Old Mar 5, 2008 | 12:08 PM
Q45tech's Avatar
Q45tech
The only guy that know for sure is the computer technican at the refinery who constantly monitors the composition stream into the holding tanks to maintain within limits. This stream gets eventually fed into pipelines where it pumps its way to your local terminal in small batches. Ocasssionally some is sampled and bulk chemicals added to fix it up if it has sat too long before shipment.
These small batches are mixed with other batches until the local terminal tanks are full of various different refineries outputs............why it's called fungible gasoline.
At the service station each refill will be slightly different day to day especially week to week depending on local turn over and wich refinery was doing what that week.
It can take 2 weeks from Texas to Washington via pipeline because it does not just go straight thru but gets diverted thru dozens of cities terminals pump stations along the way and can get sidelined and suffer for priority shipments.
Actually the only thing constant is the few drops of Marketing Additive added as the tank truck is filling up at the rack...........unless they run out of the cake coloring and have to borrow from another brand or just skip it until the rail tanker arrives tommorrow.
http://www.pipeline101.com/Overview/products-pl.html
"Colonial [pipeline] delivers 90 different products for 85 customers to
270 terminals and more than 1,000 storage tanks."
http://www.ftc.gov/bc/gasconf/commen...cobsstevee.pdf
Old Mar 5, 2008 | 12:26 PM
SteevoZ's Avatar
SteevoZ
anyone use HESS?
Old Mar 16, 2008 | 08:31 AM
Riyazsf's Avatar
Riyazsf
chevron ftw
Old Mar 16, 2008 | 10:02 AM
jonnylaw's Avatar
jonnylaw
I dunno if this is an urban myth or not but has anyone heard of the preference of filling up at night instead of sunny daytime to get most gas for the money due to less vapor loss? Bs or no??
Old Mar 16, 2008 | 12:39 PM
r0mey's Avatar
r0mey
Sunoco best gas in the country I can even get 100 octane at the pump 6.85/gallon
BP and Shell close 2nd imho
Old Mar 16, 2008 | 01:01 PM
jonnylaw's Avatar
jonnylaw
If anyone is in chicagoland area and interested in knowing what stations have 100 octane, see:
http://www.cruisintigersgto.com/for_...uel_finder.htm
Old Mar 16, 2008 | 03:55 PM
undrgnd's Avatar
undrgnd
We've all heard about that. Pure BS as far as I can surmise. Last time I looked, every filling station had a roof over the pumps to keep out rain and direct sunlight, and the tanks are buried several feet below the frost line. There is no way the earth temperature at that depth varies by more than one degree, if at all, between day and night. Maybe it's a feeble attempt by the oil companies to equalize business around the clock, although I really don't know what gave rise to that myth.
Old Mar 16, 2008 | 09:29 PM
J's 350z!'s Avatar
J's 350z!
I just put 7-11 91 octane in yesterday so far running the same as when I put 76 or chevron. I'll see at the end of this week
Old Mar 17, 2008 | 03:44 PM
  #38
superchargedg's Avatar
superchargedg
Damn Noobs
Bp in the maryland area is only 91 octane so i use texaco which is 93 or sunoco.
Old Mar 17, 2008 | 11:46 PM
  #39
J's 350z!'s Avatar
J's 350z!
Ya in California not too many places have anything over 91.
Old Mar 18, 2008 | 08:27 AM
  #40
cellphoneguy's Avatar
cellphoneguy
does anyone know what 7eleven is using now? They don't use Citgo any more from what i've heard.
