350z factory clutch?
Old Mar 3, 2008 | 12:46 PM
grey00lustre's Avatar
grey00lustre
If I replace my oem clutch and flywheel with stock ones again do I have to replace the pressure plate also? Or can I use the pressure plate on the car already? What about the throw out bearings that the dealership mention to me about?
Old Mar 23, 2009 | 11:02 AM
spinviper's Avatar
spinviper
Is the OEM Exedy NSK1000 Clutch Kit that bad ???
I dont race just want to have fun driving it. Do I really need after market ?
Old Mar 23, 2009 | 12:03 PM
BPAuto's Avatar
BPAuto
Bulletproof Automotive
If you're gonna replace your clutch and it seems to me like you want better performance out of it. Why not take a look at this?
http://www.osgiken.net/products/supersingle.html
Old Mar 23, 2009 | 02:32 PM
spinviper's Avatar
spinviper
What do you mean by performance ? In what way ?
Old Mar 23, 2009 | 02:50 PM
BPAuto's Avatar
BPAuto
As far as say handling more power yet still retaining streetability...If you've ever driven around in traffic with a Full Race Spec Clutch then you'll know what I'm talking about.
Old Apr 7, 2009 | 02:44 PM
Master Shake's Avatar
Master Shake
Anyone know if you need to do the pressure plate too? From what I have seen, it looks like if you change brands of clutch, you should match it with the same brand pressure plate -- but that might be salesperson speak. Is a new pressure plate needed for the same brand/OEM stock clutch?
I do believe you should change out the throw out bearing, however, as it tends to get a lot of wear.
