Gauge sensor mounting question . . . .
Old Feb 29, 2008 | 05:42 PM
TayTaythatsme04's Avatar
TayTaythatsme04
Default Gauge sensor mounting question . . . .
Hey Guys,
Have to mount a couple sensors for my Defi gauges, water temp and oil temp.
Now is it possible to mount the sensors without having to drain the fluids????
NOTE: I already have water and oil sensors in place that are getting replaced by these Defi's
T
Old Feb 29, 2008 | 06:02 PM
Eazzy's Avatar
Eazzy
The oil wont run out so no prob there ----The water will be fine also if you just drain a small amount so it is below the sensor level, where is that sensor??? on top ??? if so, if you drain just a qt it will be fine. Also ---use Perma-Tex Teflon paste sealant---tape sux
Sorry --misread ---Oil Temp not Pressure---your kinda screwed there
Old Feb 29, 2008 | 06:04 PM
gothchick's Avatar
gothchick
Well, to mount the water temp guage, most people tap into the upper rad hose, so you'll need to at least partially drain.
The oil sending unit will be mounted either in a oil pan spacer or a sandwich plate. so you'll need to partially drain that too.
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
