Crunchy 3rd gear????
Old Jun 26, 2003 | 08:44 AM
MadMaxZ's Avatar
MadMaxZ
Default Crunchy 3rd gear????
I was just curious if anyone out there knows if this is a common problem, or if there is any sort of a factory bulletin on this?? I've seen this on two seperate Track Edition cars now, when you shift up into 3rd pretty fast (Not speed shifting!!), and it will crunch badly. If you shift real slow it does fine. I know when I drive the car, I have yet to miss a gear, but that may have happened when someone else had driven the car? It seemed to be fine until then.... ARGH!! I am wanting to install a better clutch anyway, so I might go through the transmission just to inspect the synchros, etc., but if this is a factory recall or something, I would rather have taken care of properly. Thanks for any input or advise!!
DC
aka: MadMaxZ
Old Jun 26, 2003 | 09:06 AM
mpol99's Avatar
mpol99
Take it to your dealer. Seems like many people have had new transmissions put in.
I, personally, had a 2nd gear grind problem that only happened when I shifter fast at high rpms. Took it to my dealer, got a new transmission, problem gone.....
good luck
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
kyin
Oct 15, 2015 05:54 AM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Ace2347
Sep 22, 2015 03:12 AM
