My Dyno Results.. Unsatisfied. (Graph)
Old Mar 27, 2008 | 07:30 PM
  #41
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
I wouldnt necessarily be concerned with 243 HP. The question is how does it compare to other 350Z's or G35's on that same dyno.
All across the country (world) dynos will put out different number and some of them can vary widely.
I've seen stock range from 200 to 280 depending on the dyno used. It just happens.
Then there is the ECU. It's a very big variable. It can easily swing 10HP or more if not conditioned properly. Sometimes it goes into granny mode and sometimes it goes into performance mode depending on a number of other variables.
You could go back to that same dyno shop tomorrow and gain 10-15 more HP. The ECU can be tricky.
Ask the dyno operator if he's dynod other Z's. What numbers did they make?
Old Mar 27, 2008 | 07:45 PM
  #42
yoichi's Avatar
yoichi
Originally Posted by Alberto
Headers on most NA apps = waste of money
Tune it
I agree 100%. If you really want headers, a set of nice cams and a UTEC and you will see moderate gains. other than that, its a waste of $$$$
My N/A numbers are in my sig
Old Mar 27, 2008 | 10:12 PM
  #43
Asian Invasian's Avatar
Asian Invasian
I was the first 350z on their dyno. My power is noticeably more than stock, I am not too concerned about it anymore. I want turbo
Old Mar 27, 2008 | 10:13 PM
  #44
Teufel's Avatar
Teufel
WOW
I was thinking about doing Spacer, HFC, and exhaust....
This fred is troubling.......
Old Mar 27, 2008 | 10:41 PM
  #45
skaterbasist's Avatar
skaterbasist
Originally Posted by Asian Invasian
No I didnt, and I wish I did..
Then what are you unsatisfied about? Those numbers mean absolutely nothing without a stock baseline number. (Unless, like Hydrazine stated, you compare them to other VQ's dyno'd on the same machine in similar conditions).
Old Mar 27, 2008 | 10:54 PM
  #46
Asian Invasian
Just wanted 250whp minimum. :/
Old Mar 27, 2008 | 10:59 PM
  #47
skaterbasist
Numbers are just numbers.
I did 268 bone stock on a particular dynapack. Then, I dyno'd on a more conservative dynapack with an exhaust, test pipes, intake, & spacer and yielded 253.
Stick to one dyno and get a before & after dyno if you want to see real results.
Don't let an initial number depress you
Old Mar 28, 2008 | 05:41 AM
  #48
Hydrazine's Avatar
Hydrazine
Its a relative number. With your mods, you'll do at least 280 on my dyno.
But you will still have the same amount of power as the day before you dynod anything.
And you will still have about 20-25 more HP than stock.
Old Mar 28, 2008 | 06:08 AM
  #49
Kwame's Avatar
Kwame
Like it has already been said and as I was initially trying to express, these numbers really don't mean anything without a baseline dyno on that same exact dyno.
Ask yourself how you would feel if your baseline dyno had your car making 200whp and you've made a 40whp improvement. I'm sure at that point you wouldn't care whether you made 250whp or not. Thats all a dyno should be used for as a tool to measure the effects of modifications made on your car relative to where you started. The improvements are always more important than the overall final numbers.
Old Mar 28, 2008 | 07:05 AM
  #50
__jb's Avatar
__jb
Z + Rear Seat
This crowd is tough on headers... I have a set of Crawfords and I like them... I dyno'd 286 and my car runs great... 4.08 gears helped...
I realize that the Turbo crowd is obligated to follow the headers and all NA mods suck rule... But it isn't true.
Old Mar 28, 2008 | 07:22 AM
  #51
Zivman's Avatar
Zivman
come on now. I went down the N/A road and that was the main reason for boosting my car. Performance was pathetic for all the time and parts that I threw at the car. After everything, the car was marginally faster than the guy down the street with a bone stock Z.
If you want to stay N/A, stick to gearing and suspension type parts
Old Mar 28, 2008 | 09:26 AM
  #52
Asian Invasian
Most of the people are speaking from experience though so I believe them.
Old Mar 28, 2008 | 01:16 PM
  #53
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
given your altitude and mods, you are putting out exactly what you should expect
Old Mar 28, 2008 | 01:17 PM
  #54
Z1 Performance
Former Sponsor
Originally Posted by Nexx
you are running too rich, up top, thus hurting your peak horsepower, 12:1 is hellified rich for N/A. headers will help you lean out of bit up top. even then i would still recommend a reflash. headers + reflash will get you up into the 270's maybe into the 280's.
he's not running 12:1...he's running high 12's. Incidentally, same AFR I am running
He is 5k feet above sea level. He will NEVER see 270's or 280's with simply headers and a flash....he would be lucky to break 250
Old Mar 28, 2008 | 05:36 PM
  #55
Asian Invasian
Ill be lucky to break high 14's
Old Apr 2, 2008 | 03:15 PM
  #56
ZUPERZTAR06's Avatar
ZUPERZTAR06
anyone even get their computer reprogrammed at the guys at jetchip.com? they charge like 500 dollars for most cars. you tell them exactly what you have done to your ride and they tune it to whatever it is your using in mods
Old Apr 3, 2008 | 08:22 AM
  #57
GrayG35's Avatar
GrayG35
mines not much better... im running about as rich as you...
Old Apr 3, 2008 | 08:44 AM
  #58
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
:P
Old Apr 3, 2008 | 08:59 AM
  #59
Lawy'dU's Avatar
Lawy'dU
that sucks OP
Old Apr 3, 2008 | 09:30 AM
  #60
Cannysage's Avatar
Cannysage
don't replace the beautiful popcharger with the k&n box..
I agree with headers not doing shizzle. Your injen exhaust maybe robbing your hp. I'd chuck that heap and put on some hks. I've read many threads, where owners are claiming injen isn't a very good exhaust.
