A/C problems after TT install
So I turned on my ac for the first time since the install and it blows hot air. The compressor doesn't spin when I turn it "ON". I got to the plug on top of the comp and unplugged it to check for power and nothing. I checked the control connections and they're good. I can't find any fuse or relay that is marked A/C. Anybody got any ideas??? I'm NOT happy right now.
When the compressor doesn't spin, either it's done for, or there's no refrigerant in the system. You can manually jump the compressor to see if the clutch still spins. If it does, your A/C compressor is fine. Next check the pressure in your system to see if there's any refrigerant. If there's pressure and the pump works, check fuses/switch.
It was the refrigerant pressure sensor that they forgot to plug it back after they install the tt kit.
