injector o rings and gloves. whats the deal?
Old Apr 12, 2008 | 04:44 PM
jeffie7's Avatar
jeffie7
Default injector o rings and gloves. whats the deal?
I just installed new injectors in my car and after the fact noticed the directions said DO NOT wear gloves. I guess I skipped that part =)
why is that? I was wearing powder free latex gloves. Does the latex somehow break down the rubber o-rings?
Just wondering, if need be I'll buy some more orings and reinstall the injectors before starting the car again.
Old Apr 12, 2008 | 06:57 PM
SpoilsofWar's Avatar
SpoilsofWar
Lol, if fuel doesnt affect the orings I doubt latex could harm them.
I would imagine it has something to do with the powder that is usually applied to the gloves. Since your didn't have powder on them I would not concern myself with it.
Old Apr 13, 2008 | 10:26 PM
Eazzy's Avatar
Eazzy
Jeff --thats rediculous ---I have never seen that , but my guess is the possibility of talc from the gloves on the rings and like PAM cooking spray, creating a "nonseal"
First of all, I NEVER wear gloves and I lube my rings with appropriate lube (AC, Brake/Clutch hydraulics, Vacuum, Fuel
Even Spit
An O-ring HAS to be installed lubed
Old Apr 13, 2008 | 10:34 PM
Eazzy's Avatar
Eazzy
Point is --- Unless your ****, all O-Rings are cool with a 30 weight oil lube except AC where you want to use the appropriate refrigerant oil and a special lube for Brakes ---silicon based
Old Apr 14, 2008 | 06:58 AM
Motormouth's Avatar
Motormouth
you used ****, lube, o-ring and spit all in the span of two posts. good job.
Old Apr 14, 2008 | 03:19 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Jeff post all your questions in the fi forum cause we know you are installing a turbo setup.
Old Apr 14, 2008 | 03:24 PM
jeffie7's Avatar
jeffie7
Anything else should end up going in the install thread. =)
This one I just found weird and its not an F/I only question so I posted it here.
