I just replaced my oil pan and the oil pressure...
Old Jul 5, 2003 | 03:45 PM
y2k3350z's Avatar
y2k3350z
Default I just replaced my oil pan and the oil pressure...
seems to be higher before I replaced it, The pressure would'nt go past 80 psi knowwhen I punch it or rev it at around 4000 rpm
s it goes all the way to 120 psi is that normal.
Please those of you who can help me out post your psi readings at different revs.
Thanks.
Old Jul 5, 2003 | 10:38 PM
PhoenixINX's Avatar
PhoenixINX
My questions is...
Why are you already replacing your oil pan?!?!?!
Old Jul 6, 2003 | 01:02 AM
y2k3350z's Avatar
y2k3350z
Well here's my story. I was showing off about 2 months ago, doing some doughnuts and burning out, which was fun. Then as I was taking off hit a curb that was not visible from where my seat is adjusted at. I tought i just hit the swaybar and tore tat plastic engine cover.
Well I take it to the dealer like 2 weeks ago to get the recalls checked and the tranny noise I'm getting. The dealer takes the engine cover off and tell me I have about $1000 dollars worth of damage and thats just in parts not including labor. So I check it out, and next thing you know I fell like this .
I see the swaybar scraped up, the oil pan with a big dent in it, the a frame, a link and supposedly a strut was messed up. to finish this story out labor for just the pan was going to be $115 for a 30 minute job. Thats all it took me.
Old Jul 6, 2003 | 08:41 AM
PhoenixINX's Avatar
PhoenixINX
Wow... Man I'm sorry dude.
My only suggestions, if you're using all OEM parts make sure EVERYTHING is hooked up properly. (Not that oil pans are THAT hard)... Make sure its sealed, etc.
Old Jul 6, 2003 | 06:45 PM
y2k3350z's Avatar
y2k3350z
Thanks for the reply evil350z, so far I've put about 150 miles since I did the swap and no leaks so I think I'm good, but can you tell me your psi readings at idle, at high speeds, downshifting, and when reving high. thanks .
Old Jul 6, 2003 | 07:52 PM
Nathan's Avatar
Nathan
The only thing that can affect a before & after pressure change is the Brand,viscosity & type of oil you have used compared to what you had in before.
A higher ambient temp would also lower the press ever so slightly at start up.
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
kyin
Oct 15, 2015 05:54 AM
