Greddy oil catch can on N/A?
Old Apr 22, 2008 | 06:05 AM
Nismo350Z_00's Avatar
Nismo350Z_00
Exclamation Greddy oil catch can on N/A?
I ordered the Greddy 9mm square oil catch can. I searched some of these threads already and i can find out where i would install either of the tubes for a N/A engine. any help? Pics with makings on it.
note: I will also be adding a Kinteix SSV
note: I have an Injen CAI
Old Apr 22, 2008 | 06:16 AM
03aeroZ's Avatar
03aeroZ
this may help some, it is for a homemade catch can, but goes in same spot.
https://my350z.com/forum/showthread....ight=catch+can
Old Apr 22, 2008 | 06:19 AM
chromesilver6's Avatar
chromesilver6
opps
Old Apr 22, 2008 | 06:21 AM
chromesilver6
Heres a pic of mine. I made a custom bracket that bolts to the front cover of the engine. Worked out and great and i think it looks even better. I also put a small foam filter inside the catch can to help add with catching oil. One line will come from your pcv valve on the valve cover to the can and then out of the can into the intake manifold where the hose that was originally on the pcv was going into the manifold.
Old Apr 22, 2008 | 06:24 AM
03aeroZ's Avatar
03aeroZ
that does look good, i was going to get that catch can. it looks like it is mounted sideways though...am i wrong? if it is sideways, how does this affect it? also, can you get a closer view of the bracket...looks great and i may be doing this very soon.
Old Apr 22, 2008 | 10:07 AM
Escobar's Avatar
Escobar
that pics shows it well, its a very simple and effective install. check the diy section as aeroZ stated.
Old Apr 22, 2008 | 11:02 AM
chromesilver6
Thanks! As far as being sideways i would suggest putting a foam filter in it like i did. I just got some foam and cut it to fit in side the can. I also change the foam filter each time i change my oil so it works out very nice. I should have taken pics of the bracket when i was making it but i dont have any of it close up.
Old Apr 22, 2008 | 07:29 PM
03aeroZ's Avatar
03aeroZ
how long does it take to fill?
Old Apr 23, 2008 | 05:08 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
if its filling up on an NA setup you have major issues on hand
Old Apr 23, 2008 | 05:42 AM
chromesilver6
Well it never even gets a quarter of the way full. It has a sight tube on the side and oil doesnt even show up in there. The foam soaks in all up.
Old Apr 23, 2008 | 07:58 AM
jonnylaw's Avatar
jonnylaw
my arc ccan was almost full after 5 months of dd and a dyno session with ~15 pulls
Old Apr 23, 2008 | 08:08 AM
Z1 Performance
Former Sponsor
that's not a good sign
I've had my ARC can (the one under the strut brace) installed for about 2.5 years. Countless track days, dyno sessions, probably 35k miles since I installed it...I've never even seen anything in the site tube, nor is there anything more than a tiny blop of dirty colored water (oil particles mixed with some condensation) that has accumulates - I've yet to even drain it (mine is connected per their instructions)
Old Apr 23, 2008 | 08:35 AM
jonnylaw's Avatar
jonnylaw
damn I wonder whats going on, I better get everything checked out b4 sc install, dunno where to start tho. The can wasn't full of oil, just that stuff u saw, but a lot more than just a blotch. Recently the tubes got "discolored" as well. I just thought it was doing its job, but now I'm worried?
Old Apr 23, 2008 | 09:48 AM
gothchick's Avatar
gothchick
Mine catches oil blowby inconsistantly. Over the same length of time/milage~ Sometimes there is nothing in my can, and at other times I get a couple tablespoons worth. I dunno if it's ambient temps, driving conditions, down shifting or what that causes the inconsistancy...
I had a compression check done a few months ago and had @ 145ish across all cylinders.
Old Apr 23, 2008 | 09:52 AM
Z1 Performance
Former Sponsor
humidity I find is a big factor
Old Apr 23, 2008 | 09:55 AM
gothchick's Avatar
gothchick
Good to know. Thanks Adam~ :-)
Old Apr 23, 2008 | 07:13 PM
03aeroZ's Avatar
03aeroZ
^^great, illinois can get a$$ humid during the summer
Old Apr 25, 2008 | 03:49 PM
03aeroZ's Avatar
03aeroZ
also, would this help reduce some of that black crap buildup on the exhaust tips?
Old Apr 25, 2008 | 04:16 PM
terrasmak's Avatar
The OP is gettting a Kinetic SSV LOL
Old Apr 27, 2008 | 03:41 AM
JGTC_350z's Avatar
JGTC_350z
chromesilver6: I installed my can the same way but i'm using the other Greddy style ones but the hose actually gets "crushed" when the engine is idling ( the gas hoses you used as well ). Just wondering if there is any negative side effect of this? cause i have the 15mm tank rather than the 9mm tank like the one you have.
Any opinion guys?
