Washers for Powerlab plenum spacer
Old Apr 22, 2008 | 12:52 PM
deobiet's Avatar
deobiet
Default Washers for Powerlab plenum spacer
How many washers did you guys used on each stud/bolt to clear the strut from the plenum? I'm useing 2 at the moment and it doesn't clear it. If i use 3 then my strut would touch my hood. Anyone have any advice?
Old Apr 22, 2008 | 02:42 PM
deobiet's Avatar
deobiet
bump? anyone?
Old Apr 22, 2008 | 03:23 PM
pmohr's Avatar
pmohr
Are you using the stock strut tower bar? We use 2 washers per for our installs, but it also requires adjustment of the bar itself. Have you tried that?
Old Apr 22, 2008 | 03:28 PM
deobiet's Avatar
deobiet
Yes, i am useing the stock strut. no, i havn't tried adjusting the bar since it fitted on the bolts properly. But i'll re-adjust the bar and see if it helps. Am i suppose to tighten the bar to make it shorter or longer?
Old Apr 22, 2008 | 03:34 PM
pmohr's Avatar
pmohr
Standing from the passenger side fender, you want to turn the adjustment bolt clockwise (IIRC) to raise the bar up off of the plenum. Too far and it'll rub the hood, just FYI. Really just go a few turns either way, and you'll easily be able to tell which raises it up, and which lowers the bar down.
Old Apr 22, 2008 | 05:46 PM
DeBru_Z's Avatar
DeBru_Z
I have 3 washers on each bolt for (both sides). It's a PIA to adjust since you have to put it on and adjust the bar as mentioned above. I had to shorten the bar up to get it on the studs/align threads, then adjust the bar off the plenum.
Old Apr 23, 2008 | 10:12 AM
deobiet's Avatar
deobiet
Thx guys, Aprreciate the help. I'm going to adjust the bar today when I get off work.
burglapfd
Dec 6, 2020 01:04 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
