5/16 spacer needing tune after?
Old May 2, 2008 | 02:12 PM
spider310's Avatar
spider310
Default 5/16 spacer needing tune after?
going back and forth of getting a tune or not, would it make a difference?
Old May 2, 2008 | 02:17 PM
rr_z33's Avatar
rr_z33
it would make difference but not really needed. ecu probably will compensate enough for it.
Old May 2, 2008 | 02:24 PM
raf84ny's Avatar
raf84ny
No! Not needed if you only have a spacer.
Old May 3, 2008 | 08:49 AM
RandyK1's Avatar
RandyK1
What about if you have a 5/16 spacer, High flow cats, Borla TD Exahust and a Pop Charger? Would reseting the ECU take care of this??
Old May 3, 2008 | 08:52 AM
Yes.
Is the $$$/potential gain ratio worthwhile? That is your decision.
Old May 3, 2008 | 05:13 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Adding just a spacer makes only a very small change in A/F ratio.
If that's all you have, you will never need a tune unless your car came from the factory lean. And that's very rare.
"Most" people can put on a intake, spacer, test pipes and a catback and not require a tune. It will, however, be better with a tune.
And in the rare occasion when the car starts off lean, and all these mods are added, a tune will make really good gains. Sometimes as much as 10-15 HP.
Old May 6, 2008 | 04:34 AM
BrazenZ's Avatar
BrazenZ
What do mean by run "lean", The cpu fuel trims and O2 sensor feed back should bring the car back into specs.
Old May 6, 2008 | 08:30 AM
Hydrazine's Avatar
Hydrazine
The key word is "Should".
I got lucky . I have a G35 Sedan that ran WOT 14.0 lean since day one. Even when 100% stock it ran lean. At idle it ran 17's.
And I've been to enough dyno days to see enough vehicles dynod to see the spread in A/F ratio. They generally run high 12's to 13's. This is the norm.
But I've seen some stock vehicles run in as low as the 11's and as high as the 15's.
Old May 8, 2008 | 04:54 AM
jmccartney's Avatar
jmccartney
No you should be fine. I think I will need a tune:
Megan Test Pipes
Y pipe
Magnaflow Catback
Aem Cold Air Intake
Motordyne 5/16" Plenum Spacer
Helix Throttle Body Spacer
Competition Clutch Stage 2
Comp Light Weight Flywheel
Braided Clutch Hose
Old May 8, 2008 | 05:42 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
There is no such things that you have to do, ECU reflash is recommend when you are done mods.
Old May 8, 2008 | 10:11 AM
Asian Invasian's Avatar
Asian Invasian
Yup, mine is 12.7 WOT, with Test Pipes, Spacer, Exhaust, Intake.
Old May 8, 2008 | 03:06 PM
IIQuickSilverII's Avatar
IIQuickSilverII
OP....no
do it when you have way more mods than jsut a spacer.
PLAYDIRTY
Oct 12, 2015 07:45 AM
codek
Sep 27, 2015 03:21 PM
_koubie_
Sep 20, 2015 06:34 PM
