Stock N/A getting too hot on hillclimbs
Old May 14, 2008 | 11:44 PM
gregom's Avatar
gregom
Default Stock N/A getting too hot on hillclimbs
Every once and a bit I'll run up a mountain road here... a lot of S-Turns, uphill, 2nd gear high RPM's action. When the outside temp is over 70° F, the engine gets close to overheating toward the end of the run. Since i'm in a 5AT it will upshift to 4th and stay in that gear until I restart the engine. I usually just pull off and leave it running so the fans and rad can do their work.
My radiator coolant level is fine... so i'm not sure if this is normal or not for this car. Didn't have this problem with my previous car and it had a pretty small radiator.
Anyone had similar issues? Maybe I need to flush my coolant and refill it...
Old May 15, 2008 | 05:27 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
You may have air in the coolant system. Do a search on the subject to find a solution.
You car should never overheat in conditions like that.
Old May 15, 2008 | 05:43 AM
lucky350's Avatar
lucky350
i strongly agree, one i test drove did this and after some research that was the prob, i didnt buy that one!!!
