Automobile magazine reports poor clutch operation
Here is a comment in the July 2008 issue of Automobile magazine concerning a long term driving test of the Infiniti G37:
6259 Miles: Staffers still don’t have a cozy relationship with the G37’s pedals. “The clutch grabs too high, and the throttle is too touchy, making smooth shifts difficult,” pens Noordeloos.
Unfortunately, that is my experience with the Z as well. Smooth transitions when up-shifting or starting from a standstill seems to require running-up the RPM’s and slipping the clutch more than what I would like.
Something else… When shifting, the RPM’s remain high way too long after powering-off the accelerator pedal. This is very annoying in a car meant to provide optimum performance. My car is “stock.”
Anyone else notice these deficiencies?
--Spike
--Spike
very common complaints about these trannys.
look into the dwolf mod to help with the high engagement point. for me, it was a huge improvement.
for the rpms not dropping fast enough...maybe look into a lightened flywheel. i believe the inertia of the stock dual mass flywheel is keeping the rpms from dropping. tradeoff would be that starting from a stop may be a bit harder and some "cement mixer" noise. but the rpms should rise/fall much quicker. this is only from what i've read about lightened flywheels. i don't have first hand experience with one but plan on it in the future.
I've been given a stock g35 and stock g37 (both 6 m/t) for loaners. The g37 clutch action felt worse than the g35. Much higher engagement and for a stock setup it was really firm than totally loose up top. Hard to explain. I was very happy to be bak in my g with aftermarke clutch/flywheel and dwolf kit. I usually prefer a/t loaners from the dealer now, go figure...
^^ Interesting… That your assessment is that the G37’s drivetrain characteristics are quite different from the G35. Actually that seems to be the opinion of other testers/drivers.
--Spike
--Spike
