Noisy a** flywheel!!!!!
Old May 31, 2008 | 07:46 AM
dcreech0's Avatar
dcreech0
Default Noisy a** flywheel!!!!!
I just recently got the Jwt clutch/flywheel combo installed in my car. So much gear box chatter, its crazy! I was just wondering if there was any suggestion to quiet this problem for me. Or should i just start a search for a new flywheel?
Old May 31, 2008 | 09:00 AM
SuperBlack350z's Avatar
SuperBlack350z
light flywheels aren't for you then if you think it's loud.
Old May 31, 2008 | 10:30 AM
guitman32's Avatar
guitman32
You could raise your idle to minimize the chatter at idle (although it'll still chatter when accelerating out of low RPMs). Or you could just enjoy the improved driving experience and ignore it (my personal suggestion - after about a month you'll get used to it and wont notice it as much)
Old May 31, 2008 | 10:34 AM
Blwn_By_Twins's Avatar
Blwn_By_Twins
I agree. If you do decide to look into a different FW, check out the ACT prolite. That's what I'm running and it isn't even noticeable unless your on the gas under 2k rpm which is almost never.
Old May 31, 2008 | 10:57 AM
wannabuy350z's Avatar
wannabuy350z
good thing I read this, I hate noise like than. ACT huhh...
Old Jun 2, 2008 | 12:44 PM
350z_Gio's Avatar
350z_Gio
sry to sound dum im a noob but if you get any flywheel its going to chatter?
Old Jun 2, 2008 | 12:48 PM
Nexx's Avatar
Nexx
any lightweight flywheel, yes. the nismo might be a decent compromise.
Old Jun 2, 2008 | 01:20 PM
eltness350's Avatar
eltness350
The Untouchable
my clutchmasters stage 4 clutch/lightweight flywheel has barely any chatter.......
Old Jun 2, 2008 | 02:37 PM
Nexx's Avatar
Nexx
good to hear since thats what's on my car now.
Old Jun 2, 2008 | 03:20 PM
OPTIMO's Avatar
OPTIMO
Stop trying to make a race car then.
Old Jun 2, 2008 | 04:00 PM
Diesel350's Avatar
Diesel350
You should have gotten a 1 piece flywheel if you were worried about noise.
Old Jun 2, 2008 | 07:35 PM
Alang35's Avatar
Alang35
you mean dual mass?
Old Jun 3, 2008 | 05:51 AM
Diesel350's Avatar
Diesel350
Originally Posted by Alang35
you mean dual mass?
No, I meant the 1 piece flywheels like ACT and JUN makes less noise than JWT. If he really wanted no noise he should have just kept it stock.
Old Jun 3, 2008 | 06:01 PM
350z_Gio's Avatar
350z_Gio
Now the noise you guys are talkin about, is it like the noise that the engine makes right before it stalls when its under like 500 rpm. Sry im just trying to understand this. Thanks
Old Jun 4, 2008 | 09:19 AM
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
It's a rattle, not a stalling engine sound. The Z I'm in the process of buying has the Spec Super clutch and there is flywheel chatter. These are things you should find if you do any research before buying a mod. You're option is to either go back to stock or get used to the sound. It should only be at idle and really low RPMs like others have said.
Old Jun 5, 2008 | 09:18 AM
fpacquing's Avatar
fpacquing
I first had that bad rattling noise on nuetral. I then changed my gear oil to redline mt90. Believe it or not ; it did quiet things down. I still get that cement mixer sound below 2500 rpm but thats normal.
Old Jun 5, 2008 | 09:22 AM
SlideWays314's Avatar
SlideWays314
yep, that's why I recently went with the ACT streetlite, mainly because I couldn't find the JUN in stock anywhere...and because it's a one-piece made out of chrome-moly. mmmmmmm, chrome-moly.
Old Jun 5, 2008 | 09:25 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
I deal with the JWT clutch/flywheel chatter and I have a drop-top
Old Jun 5, 2008 | 09:46 AM
duckypower's Avatar
duckypower
i have a roadster to you get used to it but its anoying when your in a drive through its loud!!!! but for the performance diffreence its worth it!!
Old Jun 5, 2008 | 11:33 AM
350z_Gio's Avatar
350z_Gio
So is the trade off for chatter actually worth it? How does it feel with the lighter flywheel not one of those super light wheels like an average 14lb one thanks.
