Weird hissing noise under car
Old Jun 18, 2008 | 02:56 PM
MDHRZ's Avatar
MDHRZ
Default Weird hissing noise under car
Ok, I just got my car back today after having the clutch slave cylinder replaced and heard a hissing type noise under the car. It's not a constant hissing noise though. It kind of sounds like a low pitch nitrous purge. I don't think it has anything to do with the recall replacement. I'm thinking exhaust leak or fuel pump. Any ideas?
Only mod under the car is the HKS exhaust.
Old Jun 18, 2008 | 02:57 PM
marques1's Avatar
marques1
are you sure it isn't your jwt intake.
Old Jun 18, 2008 | 02:59 PM
surfcity40's Avatar
surfcity40
any fluids on the ground?
MDHRZ's Avatar
MDHRZ
Yea I checked that. Hasn't happened before. No noise there. Almost have to put my head at the bottom of the car to hear it.
Old Jun 18, 2008 | 03:04 PM
marques1's Avatar
marques1
ummmmmmmmm ok. i would probably get someone to rev the engine with you outside of the car. Make sure who ever you get to do this does not have the car in gear, lol. Just trying to keep the 350z community safe.
Old Jun 18, 2008 | 03:13 PM
MDHRZ's Avatar
MDHRZ
Did that also. I'm going to try and get it on a lift shortly so we can get under the car.
Old Jun 18, 2008 | 03:17 PM
marques1's Avatar
marques1
good luck with your car im sure you will figure it out. I'm begining to think you might have an exhaust leak!
Old Jun 18, 2008 | 03:35 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Disconnected vacuum lines?
Old Jun 18, 2008 | 04:57 PM
MDHRZ's Avatar
MDHRZ
hmmm....didn't think of that...I'll check
Old Jun 18, 2008 | 06:14 PM
TreeFiddyZee
Do WHAAAAT!?
...or maybe a seriously ticked off snake!
Old Jun 18, 2008 | 06:17 PM
haeshik's Avatar
haeshik
i was just gonna say that
Old Jun 20, 2008 | 06:13 AM
MDHRZ's Avatar
MDHRZ
Going back to the dealer today. I'll post an update when I get back.
Old Jun 22, 2008 | 03:12 PM
Barzten1's Avatar
Barzten1
I have recent clutch issues. I also have this his which I dont believe its and exhaust leak. Im woundering if its coming from or has to do with the tranny
Old Jun 22, 2008 | 03:15 PM
Spork's Avatar
Spork
Start your car, then crawl underneath and spray soapy water on all your exhaust joints. Look for bubbles or obvious streams of air.
Old Jun 22, 2008 | 03:55 PM
MDHRZ's Avatar
MDHRZ
Of course when I take it to the dealership the noise stops. It hasn't done it since and hopefully never does again. I'm going to check it out again tomorrow when I put my test pipes on.
Old Jun 22, 2008 | 04:13 PM
mavtais's Avatar
mavtais
You sure it's not the flywheel? Sometimes I get a hissing sound just before I hear the dual-mass knock against itself.
Also, I can hear a hiss while in the driver's seat. I think it's the fuel pump.
Old Jun 24, 2008 | 12:38 AM
lanceccs's Avatar
lanceccs
I got the sound as well after changing after market header and test pipe. I spoke to a few mech, they said its normal for free flowing exhaust.
Anyway its,
Fujisutbo Header
Mines Test Pipe
HKS Y Pipe
Apexi N1 Muffler
Old Jun 24, 2008 | 12:42 AM
lanceccs's Avatar
lanceccs
I got the sound as well after changing after market header and test pipe. I spoke to a few mech, they said its normal for free flowing exhaust. The hissing sound comes when RPM is dropping, be it engine braking or no load reving.
Anyway its,
Fujisutbo Header
Mines Test Pipe
HKS Y Pipe
Apexi N1 Muffler
Old Jul 10, 2008 | 06:19 AM
sunnyboy2k's Avatar
sunnyboy2k
It sounds like it could be an exhaust leak!!!
Old Jul 10, 2008 | 03:39 PM
MDHRZ's Avatar
MDHRZ
Noise is gone. Not sure what it was. Hope it doesn't come back...
