couple codes...still confused
Old Jun 24, 2008 | 05:30 AM
cracka350z's Avatar
cracka350z
Default couple codes...still confused
they were p0442 and p0327
any help would be apprieciated....i dont feel like brining it to a dealership for something i can fix.
Old Jun 24, 2008 | 06:56 AM
coachk's Avatar
coachk
Theres a sticky in this section with all the codes..
0442 is your evap and 0327 is knock knock knock
Old Jun 24, 2008 | 08:43 AM
cracka350z's Avatar
cracka350z
sorry...i was at work and had to make it quick. wasnt too clear. i got the codes (and description) but why would both of those appear at once? and would this cause severe hesitation when stepping on the gas AFTER warming up (10 min or so of driving). after that time period i have basically no power, even downshifting does squat....any ideas?
Old Jun 24, 2008 | 03:03 PM
superchargedg's Avatar
superchargedg
Damn Noobs
The evap code will not do anything but the knock code will pull timing which will reduce power.
Old Jul 1, 2008 | 06:37 AM
cracka350z's Avatar
cracka350z
well with those two codes any idea what would be causing the knock sensor to throw a code? or maybe the ks is going bad after the 113,XXX miles lol?
Old Jul 3, 2008 | 01:36 PM
cracka350z's Avatar
cracka350z
bump for an answer...its killing my MPG too...
Old Jul 3, 2008 | 01:57 PM
superchargedg
Damn Noobs
Pulling codes is one thing to guide you to the problem but you need a good tech to find the root cause.A dtc code just points a tech to the area were the problem is.....but it takes a good tech time to find the actual problem.You need to find a good tech to figure out your problem cause it is probably not going to happen on a forum.
Old Jul 3, 2008 | 04:21 PM
cracka350z's Avatar
cracka350z
eh...i was just looking for ideas so i could do it myself and wouldnt have to pay 60-90 bux an hour lol
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
Fixxxercask
Drivetrain
Sep 28, 2015 11:15 AM
