so I changed my spark plugs...
Old Jul 2, 2008 | 10:19 AM
  #41
blasian's Avatar
blasian
Originally Posted by Novesh
it was all of them, 3 and 6 were extra filthy though, like super super super super filthy, since its covered I am going to get the gasket done anyway...I gata change the plugs too...my mechanic ordered some bosche plat 2s which he installed (after the fact and I didn't even know until I drove away and called him to ask)
so I'll order some NGK's or iridium plugs better? I dunno...figure you guys do, stockers seemed fine.
Odd... yeah, get the valve cover changed and double check it again.
NGK stock plats or iridiums are fine.
Old Jul 2, 2008 | 10:20 AM
  #42
blasian's Avatar
blasian
ok so...motordyne, isothermal gasket, ngk......what else
Should be good I'd imagine. Also do what SC said
Old Jul 2, 2008 | 10:23 AM
  #43
SC 350Z's Avatar
SC 350Z
Originally Posted by blasian
You better watch out, SOLO is gonna call you dumb too
+1 on isothermal gasket... glad I have two because I'll be putting that on whenever I get my new motor.
ohwell let him and his 20 years of experince lol i dont care ,but yea those little things will help out,and the stock ngk plugs would be fine
Old Jul 2, 2008 | 11:45 AM
  #44
Z_HighSpeed's Avatar
Z_HighSpeed
sweet, thanks for all the info guys!!!! i'll post up as I go through it to see who was right and who was wrong...lol
Old Jul 2, 2008 | 12:29 PM
  #45
SC 350Z's Avatar
SC 350Z
no prob
Old Jul 2, 2008 | 12:43 PM
  #46
SC 350Z's Avatar
SC 350Z
here i did the hard work for ya
(gasket)http://www.jeimportperformance.com/items/225
(spacer)http://www.skunk2.com/mm5/merchant.m...de=307-07-0400
(plugs)http://www.trademotion.com/shoppingc...%26callout%3D4
(valve covers if needed get them from this site else where they are 200 and up)http://www.trademotion.com/partlocat...layCatalogid=0
Old Jul 2, 2008 | 03:02 PM
  #47
Z_HighSpeed
skunk 2 spacer? I though motordyne was the way to go?
Old Jul 2, 2008 | 03:56 PM
  #48
SC 350Z's Avatar
SC 350Z
couldnt find the website lol either will work fine
Old Jul 2, 2008 | 05:20 PM
  #49
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Motordyne originally designed it, and is higher quality. The rest copied. I suggest go with MD.
Old Jul 2, 2008 | 05:27 PM
  #50
Z_HighSpeed
guess its a stupid question but what width do i get
http://motordyneengineering.com/350Z.php
there are a lot of different widths...?
Old Jul 2, 2008 | 05:29 PM
  #51
blasian's Avatar
blasian
5/16" is the most popular and is what I have. It allows you to keep your stock strut bar without spacers IIRC. I had an aftermarket strut bar so I can't really say for sure.
Old Jul 2, 2008 | 05:50 PM
  #52
Z_HighSpeed
0k, so why do they make different sizes...is the gain the same? sorry about the questions just hadn't researched it
Old Jul 2, 2008 | 05:51 PM
  #53
blasian's Avatar
blasian
I think the 1/2 has the most peak but it may not be worth it
I'm sure all the sizes have different gains but the most popular is 5/16"
Old Jul 8, 2008 | 10:13 AM
  #54
KGsZ's Avatar
KGsZ
I believe the bigger it is the bigger the gain. Only problem with that is that if you go bigger then 5/16 then your stock strut wont fit. thats why the 5/16 is more popular. I read that somewhere i forgot lol
Old Jul 8, 2008 | 11:31 AM
  #55
Z_HighSpeed
hmmmm
Im buying up parts in the next few weeks...prolly gana wait to do the gasket for a bit i want to make sure I have all other parts before I do it so I don't need to get into it twice.
anyone got a list of strut bars which clear 1/2?
Old Jul 3, 2009 | 06:56 PM
  #56
UNDISPUTED's Avatar
UNDISPUTED
Default oil in plug holes
Well i thought valve cover set would include new seals but is the only way to fix oil leak into spark plug hole to replace whole valve cover???? Have any of these do it yourself with rtv held up??? would that also prevent oil leaking around top of coil on top of valve cover? I know this is an old thread but have plentum and valve covers off need stop this leak. thanks
Old Jul 4, 2009 | 06:16 AM
  #57
Z_HighSpeed
damn nearly forgot about this thread....
got my warranty company to pay for everything (parts/labor) for the valve cover gasket replacement as well as the little rubber things which keep the spark plugs from getting leaky...gana do my 5/16 iso thermal at the same time, still trying to find some good sparks probably just get new oem ones...
Old Jul 4, 2009 | 10:04 AM
  #58
UNDISPUTED's Avatar
UNDISPUTED
Default oil leak
What rubber gromments did you have replaced are they part of the coil or valve cover gasget?
Old Jul 4, 2009 | 01:17 PM
  #59
Z_HighSpeed
they didn't replace them yet, but when I do go get it done they will replace whatever it is, I'll post up then...
any recommendations on spark plugs?
Old Jul 7, 2009 | 01:08 PM
  #60
Bevo's Avatar
Bevo
I stick with OEM NGK Platinum plugs.
