how do i do the throttle body relearn procedure???
Old Jul 7, 2008 | 03:50 PM
ycdevil's Avatar
ycdevil
Default how do i do the throttle body relearn procedure???
hey i need help can anyone let me know how to the the throttle relearn procedure. i got a new throttle body and my car still wont turn on so before i take it to the dealer i want to see it the relearn procedure might help it turn on.
Old Jul 7, 2008 | 03:51 PM
Jay'Z's Avatar
Jay'Z
you search for it.
Old Jul 7, 2008 | 04:12 PM
DavesZ#3's Avatar
DavesZ#3
Accelerator Pedal Released Position Learning
DESCRIPTION
Accelerator Pedal Released Position Learning is an operation to learn the fully released position of the accelerator pedal by monitoring the accelerator pedal position sensor output signal. It must be performed each time harness connector of accelerator pedal position sensor or ECM is disconnected.
OPERATION PROCEDURE
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch ON and wait at least 2 seconds.
3. Turn ignition switch OFF and wait at least 10 seconds.
4. Turn ignition switch ON and wait at least 2 seconds.
5. Turn ignition switch OFF and wait at least 10 seconds.
Throttle Valve Closed Position Learning
DESCRIPTION
Throttle Valve Closed Position Learning is an operation to learn the fully closed position of the throttle valve by monitoring the throttle position sensor output signal. It must be performed each time harness connector of electric throttle control actuator or ECM is disconnected.
OPERATION PROCEDURE
2. Turn ignition switch ON.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning
DESCRIPTION
Idle Air Volume Learning is an operation to learn the idle air volume that keeps each engine within the specific range. It must be performed under any of the following conditions:
 Each time electric throttle control actuator or ECM is replaced.
 Idle speed or ignition timing is out of specification.
PREPARATION
Before performing Idle Air Volume Learning, make sure that all of the following conditions are satisfied.
Learning will be cancelled if any of the following conditions are missed for even a moment.
 Battery voltage: More than 12.9V (At idle)
 Engine coolant temperature: 70 - 100°C (158 - 212°F)
 Park/neutral position (PNP) switch: ON
 Electric load switch: OFF
(Air conditioner, headlamp, rear window defogger)
On vehicles equipped with daytime light systems, if the parking brake is applied before the engine is started, the headlamp will not be illuminated.
 Steering wheel: Neutral (Straight-ahead position)
 Vehicle speed: Stopped
 Transmission: Warmed-up
For A/T models with CONSULT-II, drive vehicle until “ATF TEMP SE 1” in “DATA MONITOR” mode of “A/T” system indicates less than 0.9V.
For A/T models without CONSULT-II and M/T models, drive vehicle for 10 minutes.
OPERATION PROCEDURE
With CONSULT-II
1. Perform EC-42, "Accelerator Pedal Released Position Learning" .
2. Perform EC-42, "Throttle Valve Closed Position Learning" .
3. Start engine and warm it up to normal operating temperature.
4. Check that all items listed under the topic PREPARATION (previously mentioned) are in good order.
5. Select “IDLE AIR VOL LEARN” in “WORK SUPPORT” mode.
6. Touch “START” and wait 20 seconds.
7. Make sure that “CMPLT” is displayed on CONSULT-II screen. If
“CMPLT” is not displayed, Idle Air Volume Learning will not be
carried out successfully. In this case, find the cause of the incident
by referring to the DIAGNOSIS PROCEDURE below.
8. Rev up the engine two or three times and make sure that idle
speed and ignition timing are within the specifications.
Without CONSULT-II
NOTE:
 It is better to count the time accurately with a clock.
 It is impossible to switch the diagnostic mode when an accelerator pedal position sensor circuit has a malfunction.
6. Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds.
7. Repeat the following procedure quickly five times within 5 seconds.
a. Fully depress the accelerator pedal.
b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the MIL turned ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure that idle speed and ignition timing are within the specifications.
13. If idle speed and ignition timing are not within the specification, Idle Air Volume Learning will not be carried out successfully. In this case, find the cause of the incident by referring to the DIAGNOSTIC PROCEDURE below.
Old Jul 7, 2008 | 04:50 PM
ycdevil's Avatar
ycdevil
man jay ur a jerk!
Old Jul 7, 2008 | 04:58 PM
CSF's Avatar
CSF
i keep this bookmarked:
http://www.technosquareinc.com/350reset.htm
Old Jul 7, 2008 | 05:14 PM
surfcity40's Avatar
surfcity40
Originally Posted by DavesZ#3
Blah Blah
I'm assuming that is stickied or Dave wouldn't have been able to find it....
Old Feb 26, 2012 | 08:52 PM
Wuy3502's Avatar
Wuy3502
Did it work? I have my '03 idling at 1000rpm now, the idiot workshop quoted me $1800 for an E-manage. I'm thinking of cleaning my throttle body a bit, a hard reset then perform this relearn thing.
Old Apr 4, 2012 | 11:25 AM
tcn75's Avatar
tcn75
I could not get the SES light to blink. the car's preconditions were met . what is the trick
Old Apr 4, 2012 | 11:28 AM
SuperBlack350z's Avatar
SuperBlack350z
if its not blinking, you are doing it wrong. make sure you time everything correctly.
Old Apr 6, 2012 | 12:09 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
+1
This.
I had done it several times (un-timed) and still ran into a a few times where i couldn't get the light to flash.
Honestly, the diagram helps a bit more than the instructions, rather, it clarifies the instructions a little more.
Old Apr 11, 2012 | 10:05 PM
tcn75's Avatar
tcn75
my car is 2003 .. got high idle and SES light came on after changing the spark lugs. I did the pedal dance followed above instruction many times, but didn't get the light to blink, so I google and found the easiest way to do this: " unplug the negative battery wire for 1 hour then put it back. if the SES light does not come up then you are good, otherwise you have done something wrong" It worked out for me ..
Old Aug 3, 2013 | 09:32 AM
randysduality's Avatar
randysduality
Default no result
my 03 350z revs as if i'm flooring it when i barely suppress the pedal, i tried all the reset procedures, when it comes to restarting the car on step 10 the car starts then dies, it'll restart but with no change to the revving problem i'm having, any ideas?
Old Sep 12, 2013 | 06:21 AM
Mako79's Avatar
Mako79
Sorry to wake a dead post..
Btw, did you fix it Randy?
I'm looking to clean my Throttle body but it seems there is no definitive procedure. I'm trying to Bruce-Lee the throttle body cleaning technique by learning what others have done (wrongs and right) and write up the efficient safest method.
I havent done it yet and I'm still researching.
Anyways Randy,
Try this:
Disconnect accelerator pedal position sensor. Wait 30 seconds and then reconnect.
Disconnect electric throttle control actuator. Wait 30 seconds and then reconnect.
Then do the relearn Accelerator Pedal Released Position Learning. Teaches the pedal.
Then do the relearn Throttle Valve Closed Position Learning. Teaches the TB.
This will teach the positioning as if a new part has been installed. Make sense?
Now to do the air volume learning.
Many forget that the computer will not learn unless it meets parameters below.
Warm your car up to operating temp (10minutes). Close all windows and roof (convertible). Turn off all electronics. Lave in Neutral and parking brake up with the wheels dead straight
Then do below (count 1 elephant, 2 elephant etc... and use your fingers. It's retarted but it works when you cant find a clock or see in the dark):
12. says to rev but I'm iffy on that. I say let it idle. If not repeat the steps 5 on wards this time rev a few times.
Just remember, if the Revs are too high or all over the place, the computer may not want to learn (ie save the settings).
I wonder if the technique above will fix the Throttle body issue everyone is having when they disconnect the TB for cleaning.
Old Aug 5, 2014 | 07:45 PM
ReyesM21's Avatar
ReyesM21
Sup guys.. I'm having that same problem right now.. my idle is at 1700rpm.. n I have tried the idle relearn countless times without success.. i took the car to Nissan because I couldn't figure it out n my clutch started feeling funny... n they said my clutch is slipping so I will need a new one..n that I will most likely need a new ecm to fix the idle. N they quoted me at $3500..which is ridiculous... they said since engine is idle high n I drove it like that it made the clutch go out.... did anyone find a solution.??
Old Apr 18, 2015 | 01:53 PM
Xonatron's Avatar
Xonatron
Originally Posted by CSF
I have been searching the forums, but I cannot find the instructions: How do I read my "check engine light" code? From memory, it is similar to the ECU reset procedure linked above.
Old Apr 18, 2015 | 02:04 PM
travlee's Avatar
travlee
Master
http://lmgtfy.com/?q=how+to+get+the+cel+codes+on+a+350z
Old Apr 18, 2015 | 02:07 PM
Xonatron's Avatar
Xonatron
Thanks (no thanks), but I already had my answer, it's the blinks in the middle of the ECU reset procedure, which is what I thought but is not detailed. It's explained here:
https://my350z.com/forum/engine-and-...read-code.html
Old Apr 18, 2015 | 02:10 PM
travlee's Avatar
travlee
Master
so what you are saying is...... you responded to a 6 year old post for whatever reason
Old Apr 18, 2015 | 02:17 PM
Xonatron's Avatar
Xonatron
Well, no. I had found what I was looking for but did not realize it, as it was within the ECU reset procedure but not detailed. If you didn't know, you would never know, type thing.
I'll spell it out for anyone else at the same spot:
Step #3 in the ECU reset procedure, where the CEL (SEL) blinks, is where the code is thrown. Long blinks are the first number, and short blinks are all the rest. So if you have 10 long, 4 short, 4 short, 2 short, you have 0442 being thrown. It repeats forever.
I knew this years ago, but had forgot. Hope this helps. I'm not here to waste anyone's time.
Old Apr 18, 2015 | 02:18 PM
Xonatron's Avatar
Xonatron
(P.S. "2008 Z06 Corvette" --> Nice car.)
