Anybody with a 06 base model??? Help???
Old Jul 24, 2008 | 08:07 PM
Blwn_By_Twins's Avatar
Blwn_By_Twins
Default Anybody with a 06 base model??? Help???
I've been trying to get my WOT box I got from MRC to work for almost 5 hours now with no luck. After getting help (not really) from the designer it's still not working. I need someone to look under they're dash at they're clutch and see if there is 2 switches. According to the service manual they're should be. Only in my car the is only one that is triggered AFTER you've pushed the clutch all the way down. Not one that is trigger when off the clutch. The was a plug, but it was connected to nothing. I think they fcked up in offering these for either base models, or 06+. Can anybody look for me and let me know?
Old Jul 24, 2008 | 09:14 PM
06dieselZ's Avatar
06dieselZ
where exactly is the switch supposed to be?
Edit: I think I found it. I only have a little black switch where the rubber stopper is when you press the pedal all the way down. I also have a blue plug that is connected to nothing,
Old Jul 24, 2008 | 09:26 PM
Blwn_By_Twins
If you looking at the clutch strait on, there is a switch on the right of the pedal that it hits on the way down, see yellow in pic. I have this one. It would be on the left side of the pedal more towards the top. In the green.
Old Jul 24, 2008 | 09:27 PM
Blwn_By_Twins
Yep, that's it! Your a base model as well?
Old Jul 24, 2008 | 09:31 PM
06dieselZ's Avatar
06dieselZ
Yea i have the same set up as you.
I got an 06 base
Old Jul 24, 2008 | 09:38 PM
Blwn_By_Twins
Thanks man!
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
